hmm, nice on the one side, but not nice on the other side.
most of the time when i change something it is because i did something wrong.
and when i do something wrong that leads to an errorstate.
in “normal” apps thats no problem. i edit and the app restarts automaticly “clean”
but in the “new” type of apps that isnt the case.
isnt there a way to clean up everything old at the moment an app starts?
because the end is most of the time not reached while i am developing.
Trust me - this is the easiest way. AppDaemon has no way to understand that the App has created a thread or how to clean it up - we have to do that for AppDaemon.
i trust you, but it doesnt help me.
i still need to restart appdaemon many times when i am developing apps like this.
but at least part of the times that i know needed to restart are gone.
but just thinking:
you have a terminate function to close opened threads. so you know which threads are opened right?
isnt there a way to save that with the name from the app connected to it? like in a record in a small db.
if that is possible then we could check at start from an app if old threads are cleaned up.
I am not sure you can actually clean a thread up in an App once that App has been terminated and reloaded - the way I have given you is the only way I know how to make this work. I am happy to be wrong but I don’t have a better idea at the moment, and this method works perfectly for my Apps …
Hi Andrew,
i dont have the time this week anymore. (not for testing either )
ill come back to it end of next week.
i checked out your changes and its more then i can deal with in a few minutes
like i said, its an improvement anyway. maybe not as much as had hoped, but even a small improvement is an improvement
maybe i should learn to doublecheck for typos before trying to execute
