If you are using the new API intriduced in 2.1.0, you need to make a change to your code. In this release for addiitonal flexibility, rather than giving avery App a default endpoint, Apps must now register their endpoints with the register_endpoint() call. This adds flexibility - Apps can decide on the name of the callback rather than being forced to use the default, also, Apps can now register multiple endpoints.
To retain the old behavior, you will need to add a line in your initialize() function to register the default endpoint explicity:
This will register the old default function as the callback, and use the App name as the endpoint. You are of course free to change this and rename the callback and/or use a different endpoint name as you now have the flexibility to do so.
Apart from that, the other big addition is the Custom Widget API for HADashboard! You can now easily create your own widgets and contribute them back to the community. Full documentation is included in a new section of the docs: HA Dashboard Widget Development.
And if that wasn’t enough, engrbm87 has contributed support for the Google Home API so all you Google Home users can now write apps to work with it directly.
I am also working behind the scenes to improve the docs and lay them out better.
Happy Automating!
2.1.7 (2017-08-20)
Features
Converted docs to rst for better readthedocs support
Added custom widget development
Enhanced API support to handle multiple endpoints per App
Added helper functions for Google Home’s APP.AI - contributed by engrbm87 <https://github.com/engrbm87>__
Added immediate parameter to listen state to trigger immediate evaluation of the delay parameter
Fixes
None
Breaking Changes
Existing API Apps need to register their endpoint with register_endpoint()
The AppDaemon API is a RESTFul API that allows you to call into an AppDaemon app directly from anywhere
A lot of internet enabled services ppublish webhooks that you can now use AppDaemon withm and also this allows AD Apps to directly process requests from Alexa and Google Home
you: Alexa, ask home assistant what the temperature in the livingroom ist.
Alexa: the temperature in the livingroom is 23 degrees
with AD:
you: Alexa, ask appdaemon what the temperature ist
Alexa: from what room would you like to know the temperature?
you: the livingroom
Alexa: the temperature from the livingroom is 23 degrees
Alexa: would you like to know more temperatures?
you: tell me the temperature in the bedroom
Alexa: the temperature in the bedroom is on this moment 22 degrees.
Alexa: would you want to know more?
you: no thank you
Alexa: ok, see you next time
