Which means what, exactly? Not sure where the file
directive should or would be.
Sorry - ignore that, I was on my phone and couldn’t see properly. Can you post your apps.yaml file please?
I would guess you are setting a dependency for a file that doesn’t exist.
hmm only dependency i have is for utils
which is in the apps folder.
apps.yaml
utils:
class: utils
module: utils
#### TESTING #####
Tests:
class: tests
module: tests
Transition:
class: transition_lights
module: transition_lights
dependencies: utils
Intercom:
class: intercom
module: intercom
entities:
- intercom_input: input_text.intercom
notify: googleassistant
Startup Events:
class: startup_events
module: startup_events
delay: 30
Battery Check:
module: battery_monitor
class: battery_monitor
dependencies: utils
run_time: "06:05:00"
always_send: '0'
persistent_notification: '1'
threshold: '25'
Hardware Check:
class: hardware_check
module: hardware_check
delay: '180'
log: 1
notify: 1
hue: light.mbr
zwave: light.entry_light_level
Home Assistant Events:
class: ha_event_notifier
module: ha_event_notifier
Zwave Events:
class: zwave_event_notifier
module: zwave_event_notifier
Playbar Volume Link:
class: volume_link
module: volume_link
entities:
- media_entity: media_player.sonos_playbar
input_entity: input_number.playbar_volume
Minimote 1:
class: MiniMote
module: minimote
device: zwave.minimote1
## Push
# scene_1_on:
# scene_1_off:
scene_1_toggle: light.batcave_light_level
scene_3_toggle: light.basement_hall_lights_level
scene_5_toggle: light.toy_room_lights_level
scene_7_toggle: light.tv_room_lights_level
## Hold
# scene_2_toggle: light.batcave_light
# scene_4_toggle: light.basement_hall_lights_level
# scene_6_toggle: light.toy_room_lights_level
# scene_8_toggle: light.tv_room_lights_level
monitor_notifier:
class: MonitorNotifier
module: monitor_notifier
constrain_input_boolean: input_boolean.entry_notifications
dependencies: utils
entities: group.binary_entries
reminder: '300'
ttl: '15'
Motion Notification:
class: MotionNotification
constrain_input_boolean: input_boolean.motion_notifications
constrain_presence: noone
mute_time: 3
module: motion_notification
sensors: group.binary_motion_sensors
#### Motion Lights #######################
Porch Motion PIR:
class: MotionLightSensor
module: motion_lights
binary_sensor: binary_sensor.front_porch_multisensor_motion
switch: switch.porch_lights_switch
delay: '120'
light_sensor: sensor.front_porch_multisensor_luminance
light_level: '15'
# light_slider:
constrain_start_time: "sunset - 00:15:00"
constrain_end_time: "23:00:00"
Porch Motion Doorbell:
binary_sensor: binary_sensor.ring_front_door_motion
delay: '120'
light_level: '15'
# light_slider:
LED Control:
class: GE_switch_led_control
module: GE_switch_led_control
entities:
- entity: fan.master_bedroom_fan_level
parameter: '3'
off_value: 'LED on when light on'
on_value: 'LED on when light off'
- entity: fan.living_room_fan_level
parameter: '3'
#### LIGH SCHEDULES ###########################
Lights Schedule V2 - General:
class: lights_v2
module: lights_v2
# constrain_input_boolean: input_boolean.holiday_season,off
lights:
- light: switch.eave_lights_switch
on_time: "sunset"
on_random_start: -5
on_random_end: 5
off_time: "23:00:00"
off_random_start: -5
# off_random_end: 0
## Disable if Holiday Season is 'On'
constrain_days: "mon,tue,wed,thu,fri,sat,sun"
on_time: "05:40:00"
on_random_start: -5
on_random_end: 5
off_time: "sunrise"
off_random_start: -15
# off_random_end: 0
constrain_days: "mon,tue,wed,thu,fri"
- light: switch.side_door_light_switch
on_time: "sunset"
on_random_start: -5
on_random_end: 5
off_time: "21:15:00"
# off_random_end: 0
- light: switch.back_door_light_switch
on_time: "sunset"
on_random_start: -5
on_random_end: 5
off_time: "22:00:00"
off_random_start: -10
off_random_end: 5
- light: switch.office_lamp_switch
on_time: "08:00:00"
off_time: "16:00:00"
off_time: "20:00:00"
constrain_days: "sat,sun"
### Holiday Lights #############################
Lights Schedule V2 - Holiday:
class: lights_v2
module: lights_v2
lights:
- light: switch.christmas_lights_switch
on_time: "sunset"
on_random_start: -5
on_random_end: 5
# off_random_end: 0
say_phrase: "Merry Christmas. The lights are on!"
- light: switch.christmas_tree_switch
on_time: "sunset"
on_random_start: -5
on_random_end: 5
# off_random_end: 0
on_time: "08:00:00"
on_random_start: -5
on_random_end: 5
off_time: "09:15:00"
# off_random_end: 0
Double Tap Switch:
class: zwave_double_tap
module: zwave_double_tap
dependencies: utils
entities:
## Control Lamp on double tap
- entity: zwave.living_room_light
events:
- tap_up:
- action_entity: light.living_room_lamp_level
action: 'on'
- tap_down:
action: 'off'
## Control Lamps on double tap
- entity: zwave.master_bedroom_light
events:
- tap_up:
- action_entity: light.mbr
action: 'on'
- tap_down:
action: 'off'
## Step Fan Speed
- entity: zwave.living_room_fan
events:
- tap_up:
- action_entity: fan.living_room_fan_level
action: 'on'
- tap_down:
action: 'off'
##### Simply control the same light
- entity: zwave.island_lights
events:
- tap_up:
- action_entity: light.island_lights_level
action: 'on'
- tap_down:
action: 'off'
- entity: zwave.dining_lights
events:
- tap_up:
- action_entity: light.dining_lights_level
action: 'on'
- tap_down:
action: 'off'
- entity: zwave.side_door_light
events:
- tap_up:
- action_entity: light.side_door_light_switch
action: 'on'
- tap_down:
action: 'off'
# Telegram Bot:
# class: TelegramBotEventListener
# module: telegram_bot_listener
# telegram_notifier:
# class: TelegramNotifier
# constrain_input_boolean: input_boolean.entry_notifications
# dependencies: utils
# entities: light.toy_room_lights
# module: telegram_notifier
# ttl: '1'
# RING Doorbell:
# class: ring_doorbell_video_download
# module: ring_doorbell_video_download
# entities:
# - entity: camera.front_door
# trigger_entity: sensor.ring_front_door_last_activity
# foscam_living_room:
# class: foscam_v2
# module: foscam_v2
# camsettings:
# camera_type: FI9821W V2
# camera_name: foscam_living_room_camera
# host: 192.168.1.50
# port: '88'
# user: 'admin'
# password: 'Flamingo1!'
# logsettings:
# loglevel: WARNING
# logsensorlevel: WARNING
# last_error_sensor: sensor.foscam_living_room_last_error
# picsettings:
# brightness_slider: input_number.foscam_living_room_brightness
# contrast_slider: input_number.foscam_living_room_contrast
# hue_slider: input_number.foscam_living_room_hue
# saturation_slider: input_number.foscam_living_room_saturation
# sharpness_slider: input_number.foscam_living_room_sharpness
# default_pic_settings_switch: input_boolean.foscam_living_room_default_picture_settings
# flip_switch: input_boolean.foscam_living_room_flip
# mirror_switch: input_boolean.foscam_living_room_mirror
# auto_infrared_switch: input_boolean.foscam_living_room_auto_infrared
# infrared_switch: input_boolean.foscam_living_room_infrared
# ptzsettings:
# left_right_slider: input_number.foscam_living_room_left_right
# up_down_slider: input_number.foscam_living_room_up_down
# start_cruise_select: input_select.foscam_living_room_preset_cruise
# stop_cruise_switch: input_boolean.foscam_living_room_stop_cruise
# zoom_slider: input_number.foscam_living_room_zoom
# preset_points_select: input_select.foscam_living_room_preset_points
# alarmsettings:
# motion_sensor: sensor.foscam_living_room_motion
# motion_switch: input_boolean.foscam_living_room_motion_detect
# soundalarm_sensor: sensor.foscam_living_room_sound_alarm
# sensor_update_time: '10'
# recordsettings:
# snap_picture_switch: input_boolean.foscam_living_room_snap_picture_now
# recording_sensor: sensor.foscam_living_room_recording
# save_snap_dir: /camera/foscam_living_room/
# dashboardsettings:
# use_dashboard: True
# create_dashboard: True
# create_alarm_dashboard: True
# dashboard_file_name: living_room
# alarm_dashboard_file_name: living_room_fullscreen
# screen_width: 1024
# screen_height: 600
# show_full_screen_dashboard: True
# full_screen_alarm_switch: input_boolean.foscam_living_room_toon_alarm_dash
# time_between_shows: 60
# show_time: 30
OK, it’s a bug that is making it error out instead of telling you which dependency is missing. I’ll fix the bug then maybe we can figure out what the actual error is
OK, I reproduced this and fixed the error - it was broken and also misleading. It seems to be caused when a module file is not found for an entry in apps.yaml. The fixed version will tell you which module is at fault, the fix is in dev if you want to take a look.
Is there a docker tag for Dev?
yep, it’s dev
Playing a little at the moment. Great work!
The Numbers in the sensors looked nicer in AD2.
AD3
Interesting, I’ll have to track down what the change was …
I love your work and AppDaemon is perfect for me to create a beautifull Dashboard. But now my docker “moved” from 2.1.12 to 3.0.0b1 and I probabbly missed something
Do you have any idea what I’m doing wrong on this?
2018-01-15 10:52:58.800878 INFO Configuration read from: /conf/appdaemon.yaml
File “/usr/local/bin/appdaemon”, line 11, in
load_entry_point(‘appdaemon==3.0.0b1’, ‘console_scripts’, ‘appdaemon’)()
File “/usr/local/lib/python3.6/site-packages/appdaemon/admain.py”, line 335, in main
admain.main()
File “/usr/local/lib/python3.6/site-packages/appdaemon/admain.py”, line 331, in main
self.run(appdaemon, hadashboard)
File “/usr/local/lib/python3.6/site-packages/appdaemon/admain.py”, line 58, in run
self.AD = ad.AppDaemon(self.logger, self.error, loop, **appdaemon)
File “/usr/local/lib/python3.6/site-packages/appdaemon/appdaemon.py”, line 88, in init
self.plugin_params = kwargs[“plugins”]
KeyError: ‘plugins’
Starting the docker container for the first time creates an appdaemon.conf like this:
log:
logfile: STDOUT
errorfile: STDERR
appdaeaemon: # <-- typo
threads: 10
plugins:
HASS:
ha_url:
ha_key:
should be:
log:
logfile: STDOUT
errorfile: STDERR
appdaemon:
threads: 10
plugins:
HASS:
type: hass # <-- missing
ha_url:
ha_key:
to prevent first start problems.
There have been a number of breaking changes for the 3.0 beta, described at the top of this post. You need to reorganize your appdaemon.yaml file a little, and change a few other bits and pieces.
Thanks - I’ll fix in the next release
Thank you! this was excately what I’ve missed to do. Reorganizing my appdaemon.yaml made my day :-).
Actually I’m a little more worrye about other bits and pieces, but this will become a later subject.
Have a great day!
Martin
icon_style_active in a dashboard seems to give me trouble… i.e.
device_tracker_pembo:
widget_type: device_tracker
title: 'Pembo'
entity: group.pembo
# icon_style_active: "mdi-human-male; color: #6666FF"
# icon_style_inactive: mdi-human-male
icon_on: mdi-human-male
icon_off: mdi-human-male
if I enable the icon_style sections… I get the following error
2018-01-15 22:33:56.743854 WARNING ------------------------------------------------------------
2018-01-15 22:33:56.744061 WARNING Unexpected error during DASH creation
2018-01-15 22:33:56.744206 WARNING ------------------------------------------------------------
2018-01-15 22:33:56.744519 WARNING Traceback (most recent call last):
File "/usr/local/lib/python3.5/dist-packages/appdaemon/dashboard.py", line 799, in get_dashboard
dash = self._conditional_compile(name, skin, recompile)
File "/usr/local/lib/python3.5/dist-packages/appdaemon/dashboard.py", line 751, in _conditional_compile
dash = self._get_dash(name, skin, skindir)
File "/usr/local/lib/python3.5/dist-packages/appdaemon/dashboard.py", line 554, in _get_dash
dash = self._create_dash(name, css_vars)
File "/usr/local/lib/python3.5/dist-packages/appdaemon/dashboard.py", line 436, in _create_dash
dash, layout, occupied, includes = self._create_sub_dash(name, "dash", 0, {}, [], 1, css_vars, None)
File "/usr/local/lib/python3.5/dist-packages/appdaemon/dashboard.py", line 526, in _create_sub_dash
self._add_layout(lay, layout, occupied, dash, page, includes, css_vars, global_parameters)
File "/usr/local/lib/python3.5/dist-packages/appdaemon/dashboard.py", line 410, in _add_layout
widget["parameters"] = self._load_widget(dash, includes, name, css_vars, global_parameters)
File "/usr/local/lib/python3.5/dist-packages/appdaemon/dashboard.py", line 356, in _load_widget
final_widget = self._merge_styles(final_widget, name)
File "/usr/local/lib/python3.5/dist-packages/appdaemon/dashboard.py", line 198, in _merge_styles
styles = self._get_styles(widget[key], name, key)
File "/usr/local/lib/python3.5/dist-packages/appdaemon/dashboard.py", line 185, in _get_styles
result[pieces[0].strip()] = pieces[1]
IndexError: list index out of range
2018-01-15 22:33:56.744977 WARNING ------------------------------------------------------------
2018-01-15 22:33:56.745241 INFO function [get_dashboard] finished in 168 ms
Error handling request
File "/usr/local/lib/python3.5/dist-packages/aiohttp/web_protocol.py", line 410, in start
resp = yield from self._request_handler(request)
File "/usr/local/lib/python3.5/dist-packages/aiohttp/web.py", line 325, in _handle
resp = yield from handler(request)
File "/usr/local/lib/python3.5/dist-packages/aiohttp/web_middlewares.py", line 93, in impl
return (yield from handler(request))
File "/usr/local/lib/python3.5/dist-packages/aiohttp/web_urldispatcher.py", line 142, in handler_wrapper
result = yield from result
File "/usr/local/lib/python3.5/dist-packages/appdaemon/rundash.py", line 247, in load_dash
return web.Response(text=response, content_type="text/html")
File "/usr/local/lib/python3.5/dist-packages/aiohttp/web_response.py", line 471, in __init__
type(text))
TypeError: text argument must be str (<class 'dict'>)
Am I doing something wrong/stupid??
Try removing the icon name from the styles, the styles have to be CSS, and that is incorrect syntax. The icon name belongs in the icon_off and icon_off directives as you already have it
Perfect - sure enough that’s it!
Thanks for the quick response.
Other than that, and restructuring the config, all the dashboards I have still work perfectly!
My new appdaemon.yaml looks like this for those who are struggling with the changes:
log:
logfile: STDOUT
errorfile: STDERR
logsize: 100000
log_generations: 3
appdaemon:
disable_apps: 0
threads: 10
api_port: 5000
plugins:
HASS:
type: hass
ha_url: http://192.168.x.xxx:8123
hadashboard:
dash_url: http://192.168.x.xxx:5050
I’m using docker and pulling latest, any way I can stay on version 2?
latest dev branch error preventing AD from starting
File "/usr/local/bin/appdaemon", line 11, in <module>
load_entry_point('appdaemon==3.0.0b1', 'console_scripts', 'appdaemon')()
File "/usr/local/lib/python3.6/site-packages/pkg_resources/__init__.py", line 572, in load_entry_point
return get_distribution(dist).load_entry_point(group, name)
File "/usr/local/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2752, in load_entry_point
return ep.load()
File "/usr/local/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2405, in load
return self.resolve()
File "/usr/local/lib/python3.6/site-packages/pkg_resources/__init__.py", line 2411, in resolve
module = __import__(self.module_name, fromlist=['__name__'], level=0)
File "/usr/local/lib/python3.6/site-packages/appdaemon/admain.py", line 17, in <module>
import appdaemon.adapi as api
File "/usr/local/lib/python3.6/site-packages/appdaemon/adapi.py", line 4, in <module>
from aiohttp import web
File "/usr/local/lib/python3.6/site-packages/aiohttp/web.py", line 15, in <module>
from . import (hdrs, web_exceptions, web_fileresponse, web_middlewares,
File "/usr/local/lib/python3.6/site-packages/aiohttp/web_middlewares.py", line 5, in <module>
from aiohttp.web_urldispatcher import SystemRoute
File "/usr/local/lib/python3.6/site-packages/aiohttp/web_urldispatcher.py", line 21, in <module>
from yarl import URL, unquote
ImportError: cannot import name 'unquote'
