TL;DR - AppDaemon 3.0 is here - it’s a beta and it brings a few breaking changes - in particular, python 3.4 is no longer supported. Please read on for more detail.
NOTE: The link to the beta docs is here:
http://appdaemon.readthedocs.io/en/latest/
If you want the old version 2 docs, they can be found here:
http://appdaemon.readthedocs.io/en/stable/
Hi all - it’s been a little while but I am hoping the wait will be worth it - introducing AppDaemon 3.0 beta1!
In addition to some new functionality (listed below), I have completely rewritten and re-architected sections of AppDaemon, and as such I wanted to release this initially as a beta to see if any of you brave souls out there would kick the tires for me and let me know about any issues. As far as I know it is stable and I have been using it myself for many weeks with no issues, but you never know!
The main reasons for the rewrite was twofold:
- I want to integrate AppDaemon very closely with Home Assistant, and in order to do that the best possible way, I needed to make some changes to the way the code was structured
- I wanted to introduce the concept of pluggable support. In AD 3.0, the HASS support is a plugin, one of potentially many - for instance it is now possible to write an OpenHab plugin for instance and have AD work with both at the same time. (I have no plans to do that , but others might). A more practical outcome of the way the plugin support is implementes is that it is now possible to run AppDaemon connected to multiple HASS instances if you desire.
I have also taken this opportunity to make some changes and some of them are breaking changes. I haven;t done this lightly and I’ll explain below what the changes are, and why I made them - in most cases I have good reason
Note that not all changes will apply to everyone, some of them are in fairly obscure parts of AppDaemon that few if any people use, however, everyone will have to mnake some changes, so read carefully.
- AppDaemon no longer supports python 3.4
This is a fairly significant step, and the decision to do this was influenced by HASS’ pending end of support for Python 3.4. There are many technical reasons why this is a good thing, but the bottom line is that you will need to upgrade your pyton version to run HASS anyway, so I took this opportunity to follow suit. AppDaemon 3.0 will remain in beta until HASS drops python 3.4 support entirely.
- Apps need to change the import and super class
The naming and placement of the imports needed to change to support the plugin architecture, and to make more sense of the naming in a multiple plugin environment. You will need to edit each of your apps and change the top couple of lines from:
import appdaemon.appapi as appapi
class MyClass(appapi.AppDaemon):
to:
import appdaemon.plugins.hass.hassapi as hass
class MyClass(hass.Hass):
Note, we are changing both the import name, and the superclass.
info_listen_state()
now returns the namespace in addition to the previous parameters
I introduced namespaces as a way of handling multiple plugins at the same time - the docs have more details, but if you are just using a single HASS instance, as everyone has been doing until now, you can safely ignore namespaces.
- The “ha_started” event has been renamed to “plugin_started”
If you use this event, the name has been changed. The plugin started event has a parameter called name
which gives the name of the plugin that was restarted.
- RSS Feed parameters have been moved to the hadashboard section
When HADashboard is integrated with HASS, the config for HADashboard needs to be all in one place.
e.g.:
hadashboard:
dash_url: http://192.168.1.20:5050
rss_feeds:
- feed: http://rss.cnn.com/rss/cnn_topstories.rss
target: news
rss_update: 300
- Log directives now have their own section
Logging is a function of the underlying execution code, not specifically AppDaemon (for instance, when integrated with HASS, AppDaemon will use HASS logging. For that Reason, the log directives were pulled out into their own section. The section is optional, and if not specified all the previous defaults will apply.
For example:
log:
accessfile: /export/hass/appdaemon_test/logs/access.log
errorfile: /export/hass/appdaemon_test/logs/error.log
logfile: /export/hass/appdaemon_test/logs/appdaemon.log
log_generations: 5
log_size: 1024
appdaemon:
AppDaemon
section renamed toappdaemon
,HADashboard
section renamed tohadashboard
This was done mainly for consistency, and because the capitals bugged me
- Plugins (such as the HASS plugin now have their own parameters under the plugin section of the config file
This comes down to a reorganization of the apps.yaml file to reflect the fact that there are now plugins and there may be more than one of them. Rather than having it’s own section, the HASS plugin is now listed under the appdaemon
section, although the arguments remain the same. Here is an example:
appdaemon:
api_port: 5001
api_key: !secret appdaemon_key
threads: 10
time_zone: GMT+0BST-1,M3.5.0
plugins:
HASS:
type: hass
ha_key: !secret home_assistant_key
ha_url: http://192.168.1.20:8123
#commtype: SSE
- –commtype command line argument has been moved to the appdaemon.cfg file
This parameter applies specifically to HASS, so it made no sense to have it as a commandline argument. See above for an example.
- Accessing other Apps arguments is now via the
app_config
attribute,config
retains just the AppDaemon configuration parameters
Required due to the restructuring of the config files.
- the self.ha_config attribute has been replaced by the
self.get_hass_config()
api call and now supports namespaces.
This reflects the fact that the yaml files have been reconfigured, and that the config info is now owned by the individual plugins.
- The !secret directive has been moved to the top level of appdaemon.yaml
The same argument as the logs - not strictly relevant to AppDaemon, more a concern of the execution environment.
- apps.yaml in the config directory has now been deprecated
One of the new features in 3.0 is that it is now possible to split the apps.yaml into multiple files. You are free to do this in any way you want and place the yaml files with any name, anywhere in the directoty hierarchy under the appdir. Apart from flexibility, another reason for this was to prepare the way for later features around configuration tools and automatic app installs. For now, the only necessary step is to move your apps.yaml file from the config dircetory into the apps directory. If you do not, you will get a warning but everything should still work for now. If you do stick with apps.yaml at in the config directory for now, any other yaml files in the apps directory will be ignored.
- select_value() has been renamed to set_value() to harmonize with HASS
A minor change just to reflect the recent changes to HASS in this area, e.g input_slider
being renamed to input_number
and the sevice name changing.
- It is no longer possible to automatically migrate from the legacy cfg style of config, and support for cfg files has been dropped.
This has been on the cards for a while - if yo uare still using cfg files, use the latest 2.0 version of appdaemon to migrate to yaml style configuration before you upgrade to 3.0.
That’s it for the breaking changes. I intend to keep AppDaemon at beta for a while, and there will be additional functionality added in future beta versions, I have a targeted list and will add new stuff as I go along before I release the GA version.
To install 3.0b1 using pip, you will need to specify the -pre
flag to pick up the beta. Docker users I believe should pick up the beta automatically if they are specifying the latest
image.
That’s it for now - please report any issues and/or ask questions on this thread so we can keep all of the accumulated wisdom in one place.
Enjoy!
3.0.0b1 (2018-01-12)
Features
- Refactored pluggable architecture
- Support for multiple HASS instances
- Custom constraints
- Namespaces
- Path of Secret file can now be specified
- apps.yaml can now be split across multiple files and directories
- Apps can now establish loading priorities to influence their loading order
- IFRAME Refreshes should now be more reliable
- Added calls to access the underlying logger objects for the main and error logs
- Add the ability to ignore specific subdirectories under appdir
- Added error handling for apps that can’t be read or have broken links
- Added london Underground Widget - contributed by
mmmmmmtasty <https://github.com/mmmmmtasty>
__ - Added ability to display sensor attributes - contributed by
__ - Added Weather Summary Widget - contributed by
__ - Added Sticky navigation - contributed by
Lars Englund <https://github.com/larsenglund>
__ - Added Input Select widget - contributed by
Rene Tode <https://github.com/ReneTode>
__ - Redesigned Input Number widget (old is still available as
input_slider
) - contributed byRene Tode <https://github.com/ReneTode>
__ - Added Radial widget - contributed by
__ - Added Temperature widget - contributed by
__ - Added container style to sensor widget - contributed by
__
Fixes
- Fixed an issue with the compiled directory not being created early enough
Breaking Changes
info_listen_state()
now returns the namespace in addition to the previous parameters - AppDaemon no longer supports python 3.4
AppDaemon
,HADashboard
app_config
attribute,config
retains just the AppDaemon configuration parameters - Plugins (such as the HASS plugin now have their own parameters under the plugin section of the config file
api call and now supports namespaces. - apps.yaml in the config directory has now been deprecated
