yeah, i noticed it to and mentioned it to Andrew
I’m taking a detailed look at this area soon - I’ve made some piecemeal changes over the releases and it’s time for me to rework it. I’ll also be making dependencies work at the app level instead of the module level.
in HAdashboard the
icon_on: mdi-door-open
icon_off: mdi-door-closed
is not recognised (no icon is chosen). This happens with some other icon as well. Not sure where the problem lays
These for exampe works well
icon_on: mdi-window-open
icon_off: mdi-window-closed
MDI adds new icons once in a while.
some new icons then are not recognized untill there is a new update in appdaemon.
Ok thanks, will wait update for putting the door icon
I thought i can fix this issue from the beta 1 topic with a own skin.
Copied the default dashboard.css and variales.yaml to custom_css/skinname and started to play, but with no luck.
All i found that affects the sensor value was:
.widget {
vertical-align: middle;
but it seems that only accepts top, middle or bottom.
Any hints on this?
Thanks in advance!
use the variables.yaml and just change where there is a problem. in this case the sensor variables.
i think you want to change the top from the container like top: 42px
I just finished upgrading to the beta and I have apps disabled but I am still receiving this error:
pi@raspberrypi:~ $ appdaemon -c /home/homeassistant/conf
2018-02-06 11:45:57.677528 INFO AppDaemon Version 3.0.0b2 starting
2018-02-06 11:45:57.678153 INFO Configuration read from: /home/homeassistant/conf/appdaemon.yaml
2018-02-06 11:45:57.680273 INFO AppDaemon: Starting Apps
2018-02-06 11:45:57.680764 ERROR AppDaemon: Invalid value for app_dir: /home/homeassistant/conf/apps
2018-02-06 11:45:57.681152 INFO Dashboards are disabled
2018-02-06 11:45:57.681456 INFO API is disabled
2018-02-06 11:45:57.682595 INFO AppDeamon Exited
My config:
log:
logfile: STDOUT
errorfile: STDERR
appdaemon:
disable_apps: 1
threads: 10
plugins:
HASS:
type: hass
ha_url: http://URL
ha_key: KEY
HADashboard:
dash_url: http://URL
Do I have to configure the test app?
FOr now, at least create the apps dir - I’ll fix it so disable_apps doesn’t require it in the next beta.
EDIT: No it’s working as designed from my testing - you just need
disable_apps: true
Ok, but now I get this:
2018-02-06 11:58:38.017761 INFO AppDaemon Version 3.0.0b2 starting
2018-02-06 11:58:38.018405 INFO Configuration read from: /home/homeassistant/conf/appdaemon.yaml
2018-02-06 11:58:38.021421 INFO AppDaemon: Apps are disabled
File "/usr/local/bin/appdaemon", line 11, in <module>
sys.exit(main())
File "/home/pi/.local/lib/python3.5/site-packages/appdaemon/admain.py", line 341, in main
admain.main()
File "/home/pi/.local/lib/python3.5/site-packages/appdaemon/admain.py", line 337, in main
self.run(appdaemon, hadashboard)
File "/home/pi/.local/lib/python3.5/site-packages/appdaemon/admain.py", line 59, in run
self.AD = ad.AppDaemon(self.logger, self.error, loop, **appdaemon)
File "/home/pi/.local/lib/python3.5/site-packages/appdaemon/appdaemon.py", line 236, in __init__
self.app_config = self.read_config()
File "/home/pi/.local/lib/python3.5/site-packages/appdaemon/appdaemon.py", line 1458, in read_config
if root[-11:] != "__pycache__":
TypeError: 'NoneType' object is not subscriptable
@aimc The error is much more simple if I try and start the appdaemon service:
Feb 06 12:00:42 raspberrypi systemd[1]: Started AppDaemon.
Feb 06 12:00:45 raspberrypi appdaemon[25919]: Traceback (most recent call last):
Feb 06 12:00:45 raspberrypi appdaemon[25919]: File "/usr/local/bin/appdaemon", line 11, in <module>
Feb 06 12:00:45 raspberrypi appdaemon[25919]: sys.exit(main())
Feb 06 12:00:45 raspberrypi appdaemon[25919]: File "/usr/local/lib/python3.5/dist-packages/appdaemon/admain.py", line 230, in main
Feb 06 12:00:45 raspberrypi appdaemon[25919]: conf.logfile = config['AppDaemon'].get("logfile")
Feb 06 12:00:45 raspberrypi appdaemon[25919]: KeyError: 'AppDaemon'
There have been changes in b3 that seem to address this, it works fine for me on my dev version.
For now, add the hello world app and re-enable apps.
@aimc Still the same error after enabling apps. Something to do with logs?
Should I uninstall and start from scratch?
Feb 06 12:25:02 raspberrypi systemd[1]: Started AppDaemon.
Feb 06 12:25:05 raspberrypi appdaemon[26435]: Traceback (most recent call last):
Feb 06 12:25:05 raspberrypi appdaemon[26435]: File "/usr/local/bin/appdaemon", line 11, in <module>
Feb 06 12:25:05 raspberrypi appdaemon[26435]: sys.exit(main())
Feb 06 12:25:05 raspberrypi appdaemon[26435]: File "/usr/local/lib/python3.5/dist-packages/appdaemon/admain.py", line 230, in main
Feb 06 12:25:05 raspberrypi appdaemon[26435]: conf.logfile = config['AppDaemon'].get("logfile")
Feb 06 12:25:05 raspberrypi appdaemon[26435]: KeyError: 'AppDaemon'
Feb 06 12:25:05 raspberrypi systemd[1]: [email protected]: Main process exited, code=exited, status=1/FAILURE
Feb 06 12:25:05 raspberrypi systemd[1]: [email protected]: Unit entered failed state.
Feb 06 12:25:05 raspberrypi systemd[1]: [email protected]: Failed with result 'exit-code'.
Sorry missed that - the fact it is asking for AppDameon means you aren’t
running 3.0b2 from systemd - I suspect you have 2 different installs.
@aimc So I uninstalled appdaemon and installed the beta again. Created the conf directory with apps directory and appdaemon.yaml. Inside apps directory I have apps.yaml and hello.py.
hello.py:
# Hello World App
# Args:
class HelloWorld(hass.Hass):
def initialize(self):
self.log("Hello from AppDaemon")
self.log("You are now ready to run Apps!")
apps.yaml:
hello_world:
module: hello
class: HelloWorld
appdaemon.yaml:
appdaemon:
logfile: STDOUT
errorfile: STDERR
logsize: 100000
log_generations: 3
threads: 10
plugins:
HASS:
type: hass
ha_url: http://URL
ha_key: KEY
namespace: default
HADashboard:
Anything else I am missing?
@aimc Made some progress. Now If I remove the:
HADashboard:
from the appdaemon.yaml, appdaemon starts with no errors but if I add then I get:
2018-02-06 13:58:34.596040 INFO AppDaemon Version 3.0.0b2 starting
2018-02-06 13:58:34.597068 INFO Configuration read from: /home/homeassistant/conf/appdaemon.yaml
2018-02-06 13:58:34.599367 INFO AppDaemon: Starting Apps
sys.exit(main())
admain.main()
File "/home/pi/.local/lib/python3.5/site-packages/appdaemon/appdaemon.py", line 257, in __init__
basename = self.plugins[name]["type"]
KeyError: 'type'
Up and running . Here’s my config in case someone runs into these issues:
log:
logfile: STDOUT
errorfile: STDERR
logsize: 100000
log_generations: 3
appdaemon:
threads: 10
plugins:
HASS:
type: hass
ha_url: http://URL
ha_key: KEY
namespace: default
hadashboard:
get_state()
seems to have slightly different behavior when attempting to grab the entire state dictionary via attribute=all
Example: self.get_state('input_boolean.test', attribute=all)
returns only the attributes of that input boolean; the state itself is not included in the dictionary:
{'friendly_name': 'Test', 'icon': 'mdi:calendar'}
