I just finished upgrading to the beta and I have apps disabled but I am still receiving this error:
pi@raspberrypi:~ $ appdaemon -c /home/homeassistant/conf
2018-02-06 11:45:57.677528 INFO AppDaemon Version 3.0.0b2 starting
2018-02-06 11:45:57.678153 INFO Configuration read from: /home/homeassistant/conf/appdaemon.yaml
2018-02-06 11:45:57.680273 INFO AppDaemon: Starting Apps
2018-02-06 11:45:57.680764 ERROR AppDaemon: Invalid value for app_dir: /home/homeassistant/conf/apps
2018-02-06 11:45:57.681152 INFO Dashboards are disabled
2018-02-06 11:45:57.681456 INFO API is disabled
2018-02-06 11:45:57.682595 INFO AppDeamon Exited
2018-02-06 11:58:38.017761 INFO AppDaemon Version 3.0.0b2 starting
2018-02-06 11:58:38.018405 INFO Configuration read from: /home/homeassistant/conf/appdaemon.yaml
2018-02-06 11:58:38.021421 INFO AppDaemon: Apps are disabled
File "/usr/local/bin/appdaemon", line 11, in <module>
sys.exit(main())
File "/home/pi/.local/lib/python3.5/site-packages/appdaemon/admain.py", line 341, in main
admain.main()
File "/home/pi/.local/lib/python3.5/site-packages/appdaemon/admain.py", line 337, in main
self.run(appdaemon, hadashboard)
File "/home/pi/.local/lib/python3.5/site-packages/appdaemon/admain.py", line 59, in run
self.AD = ad.AppDaemon(self.logger, self.error, loop, **appdaemon)
File "/home/pi/.local/lib/python3.5/site-packages/appdaemon/appdaemon.py", line 236, in __init__
self.app_config = self.read_config()
File "/home/pi/.local/lib/python3.5/site-packages/appdaemon/appdaemon.py", line 1458, in read_config
if root[-11:] != "__pycache__":
TypeError: 'NoneType' object is not subscriptable
@aimc The error is much more simple if I try and start the appdaemon service:
Feb 06 12:00:42 raspberrypi systemd[1]: Started AppDaemon.
Feb 06 12:00:45 raspberrypi appdaemon[25919]: Traceback (most recent call last):
Feb 06 12:00:45 raspberrypi appdaemon[25919]: File "/usr/local/bin/appdaemon", line 11, in <module>
Feb 06 12:00:45 raspberrypi appdaemon[25919]: sys.exit(main())
Feb 06 12:00:45 raspberrypi appdaemon[25919]: File "/usr/local/lib/python3.5/dist-packages/appdaemon/admain.py", line 230, in main
Feb 06 12:00:45 raspberrypi appdaemon[25919]: conf.logfile = config['AppDaemon'].get("logfile")
Feb 06 12:00:45 raspberrypi appdaemon[25919]: KeyError: 'AppDaemon'
@aimc Still the same error after enabling apps. Something to do with logs?
Should I uninstall and start from scratch?
Feb 06 12:25:02 raspberrypi systemd[1]: Started AppDaemon.
Feb 06 12:25:05 raspberrypi appdaemon[26435]: Traceback (most recent call last):
Feb 06 12:25:05 raspberrypi appdaemon[26435]: File "/usr/local/bin/appdaemon", line 11, in <module>
Feb 06 12:25:05 raspberrypi appdaemon[26435]: sys.exit(main())
Feb 06 12:25:05 raspberrypi appdaemon[26435]: File "/usr/local/lib/python3.5/dist-packages/appdaemon/admain.py", line 230, in main
Feb 06 12:25:05 raspberrypi appdaemon[26435]: conf.logfile = config['AppDaemon'].get("logfile")
Feb 06 12:25:05 raspberrypi appdaemon[26435]: KeyError: 'AppDaemon'
Feb 06 12:25:05 raspberrypi systemd[1]: [email protected]: Main process exited, code=exited, status=1/FAILURE
Feb 06 12:25:05 raspberrypi systemd[1]: [email protected]: Unit entered failed state.
Feb 06 12:25:05 raspberrypi systemd[1]: [email protected]: Failed with result 'exit-code'.
@aimc So I uninstalled appdaemon and installed the beta again. Created the conf directory with apps directory and appdaemon.yaml. Inside apps directory I have apps.yaml and hello.py.
hello.py:
import appdaemon.plugins.hass.hassapi as hass
# Hello World App
# Args:
class HelloWorld(hass.Hass):
def initialize(self):
self.log("Hello from AppDaemon")
self.log("You are now ready to run Apps!")
from the appdaemon.yaml, appdaemon starts with no errors but if I add then I get:
2018-02-06 13:58:34.596040 INFO AppDaemon Version 3.0.0b2 starting
2018-02-06 13:58:34.597068 INFO Configuration read from: /home/homeassistant/conf/appdaemon.yaml
2018-02-06 13:58:34.599367 INFO AppDaemon: Starting Apps
sys.exit(main())
admain.main()
File "/home/pi/.local/lib/python3.5/site-packages/appdaemon/appdaemon.py", line 257, in __init__
basename = self.plugins[name]["type"]
KeyError: 'type'
get_state() seems to have slightly different behavior when attempting to grab the entire state dictionary via attribute=all.
Example: self.get_state('input_boolean.test', attribute=all) returns only the attributes of that input boolean; the state itself is not included in the dictionary:
