One more bugfix for older tablets - thanks again @ReneTode
4.0.8 (2021-03-30)
Features
None
Fixes
- Fixed issue with Dashboard
icon
widgets breaking - contributed byRene Tode <https://github.com/ReneTode>
__
Breaking Changes
None
Features
None
Fixes
icon
widgets breaking - contributed by Rene Tode <https://github.com/ReneTode>
__Breaking Changes
None
this was actually for all dashboards
the new icon widget wasnt tested good enough, im afraid. (blame me, i didnt test it at all, but gave odia approvement to implement )
Upgrade is failing while building wheel for uvloop. I did a quick search but found nothing relevant so far. is this a known issue?
nope. your the first with that issue.
to be able to say more about it youll need to tell more about your environment.
its has gone flawless for a lot off people with:
Home Assistant Core on a Pi 3b+, AppDaemon 4.0.5, HA 2021.3.4
Building wheels for collected packages: uvloop
Building wheel for uvloop (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: /usr/local/bin/python3.8 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-wevq14xd/uvloop_fa97f35bf09f412e9b2534726526384a/setup.py'"'"'; __file__='"'"'/tmp/pip-install-wevq14xd/uvloop_fa97f35bf09f412e9b2534726526384a/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-9ri_yhy6
cwd: /tmp/pip-install-wevq14xd/uvloop_fa97f35bf09f412e9b2534726526384a/
Complete output (244 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.8
creating build/lib.linux-armv7l-3.8/uvloop
copying uvloop/__init__.py -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/_noop.py -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/_testbase.py -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/_version.py -> build/lib.linux-armv7l-3.8/uvloop
running egg_info
writing uvloop.egg-info/PKG-INFO
writing dependency_links to uvloop.egg-info/dependency_links.txt
writing requirements to uvloop.egg-info/requires.txt
writing top-level names to uvloop.egg-info/top_level.txt
reading manifest file 'uvloop.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no previously-included files matching '*' found under directory 'vendor/libuv/.git'
warning: no previously-included files matching '*' found under directory 'vendor/libuv/docs'
warning: no previously-included files matching '*' found under directory 'vendor/libuv/img'
writing manifest file 'uvloop.egg-info/SOURCES.txt'
copying uvloop/cbhandles.pxd -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/cbhandles.pyx -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/dns.pyx -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/errors.pyx -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/loop.c -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/loop.pxd -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/loop.pyi -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/loop.pyx -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/lru.pyx -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/pseudosock.pyx -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/py.typed -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/request.pxd -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/request.pyx -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/server.pxd -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/server.pyx -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/sslproto.pxd -> build/lib.linux-armv7l-3.8/uvloop
copying uvloop/sslproto.pyx -> build/lib.linux-armv7l-3.8/uvloop
creating build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/async_.pxd -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/async_.pyx -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/basetransport.pxd -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/basetransport.pyx -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/check.pxd -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/check.pyx -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/handle.pxd -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/handle.pyx -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/idle.pxd -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/idle.pyx -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/pipe.pxd -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/pipe.pyx -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/poll.pxd -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/poll.pyx -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/process.pxd -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/process.pyx -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/stream.pxd -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/stream.pyx -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/streamserver.pxd -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/streamserver.pyx -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/tcp.pxd -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/tcp.pyx -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/timer.pxd -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/timer.pyx -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/udp.pxd -> build/lib.linux-armv7l-3.8/uvloop/handles
copying uvloop/handles/udp.pyx -> build/lib.linux-armv7l-3.8/uvloop/handles
creating build/lib.linux-armv7l-3.8/uvloop/includes
copying uvloop/includes/__init__.py -> build/lib.linux-armv7l-3.8/uvloop/includes
copying uvloop/includes/compat.h -> build/lib.linux-armv7l-3.8/uvloop/includes
copying uvloop/includes/consts.pxi -> build/lib.linux-armv7l-3.8/uvloop/includes
copying uvloop/includes/debug.h -> build/lib.linux-armv7l-3.8/uvloop/includes
copying uvloop/includes/debug.pxd -> build/lib.linux-armv7l-3.8/uvloop/includes
copying uvloop/includes/flowcontrol.pxd -> build/lib.linux-armv7l-3.8/uvloop/includes
copying uvloop/includes/fork_handler.h -> build/lib.linux-armv7l-3.8/uvloop/includes
copying uvloop/includes/python.pxd -> build/lib.linux-armv7l-3.8/uvloop/includes
copying uvloop/includes/stdlib.pxi -> build/lib.linux-armv7l-3.8/uvloop/includes
copying uvloop/includes/system.pxd -> build/lib.linux-armv7l-3.8/uvloop/includes
copying uvloop/includes/uv.pxd -> build/lib.linux-armv7l-3.8/uvloop/includes
running build_ext
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking build system type... armv7l-unknown-linux-gnueabihf
checking host system type... armv7l-unknown-linux-gnueabihf
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking whether make supports the include directive... yes (GNU style)
checking dependency style of gcc... gcc3
checking for gcc way to treat warnings as errors... -Werror
checking if gcc supports -fvisibility=hidden... yes
checking if gcc supports -g flag... yes
checking if gcc supports -std=gnu89 flag... yes
checking if gcc supports -Wall flag... yes
checking if gcc supports -Wextra flag... yes
checking if gcc supports -Wno-long-long flag... yes
checking if gcc supports -Wno-unused-parameter flag... yes
checking if gcc supports -Wstrict-prototypes flag... yes
checking for ar... ar
checking the archiver (ar) interface... ar
checking how to print strings... printf
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /usr/bin/ld
checking if the linker (/usr/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking how to convert armv7l-unknown-linux-gnueabihf file names to armv7l-unknown-linux-gnueabihf format... func_convert_file_noop
checking how to convert armv7l-unknown-linux-gnueabihf file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for a working dd... /bin/dd
checking how to truncate binary pipes... /bin/dd bs=4096 count=1
checking for mt... mt
checking if mt is a manifest tool... no
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... yes
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking whether make supports nested variables... (cached) yes
checking whether gcc is Clang... no
checking whether pthreads work with -pthread... yes
checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
checking whether more special flags are required for pthreads... no
checking for PTHREAD_PRIO_INHERIT... yes
checking for dlopen in -ldl... yes
checking for library containing kstat_lookup... no
checking for library containing gethostbyname... none required
checking for library containing perfstat_cpu... no
checking for library containing clock_gettime... none required
checking for library containing sendfile... none required
checking for library containing socket... none required
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... 64
checking sys/ahafs_evProds.h usability... no
checking sys/ahafs_evProds.h presence... no
checking for sys/ahafs_evProds.h... no
checking that generated files are newer than configure... done
configure: creating ./config.status
config.status: creating Makefile
config.status: creating libuv.pc
config.status: executing depfiles commands
config.status: executing libtool commands
CC src/libuv_la-fs-poll.lo
CC src/libuv_la-idna.lo
CC src/libuv_la-inet.lo
CC src/libuv_la-random.lo
CC src/libuv_la-strscpy.lo
CC src/libuv_la-threadpool.lo
CC src/libuv_la-timer.lo
CC src/libuv_la-uv-data-getter-setters.lo
CC src/libuv_la-uv-common.lo
CC src/libuv_la-version.lo
CC src/unix/libuv_la-async.lo
CC src/unix/libuv_la-core.lo
CC src/unix/libuv_la-dl.lo
CC src/unix/libuv_la-fs.lo
CC src/unix/libuv_la-getaddrinfo.lo
src/unix/fs.c: In function ‘uv__fs_sendfile’:
src/unix/fs.c:909:57: warning: passing argument 4 of ‘uv__fs_copy_file_range’ from incompatible pointer type [-Wincompatible-pointer-types]
r = uv__fs_copy_file_range(in_fd, NULL, out_fd, &off, req->bufsml[0].len, 0);
In file included from src/unix/internal.h:41,
from src/unix/fs.c:30:
src/unix/linux-syscalls.h:71:33: note: expected ‘ssize_t *’ {aka ‘int *’} but argument is of type ‘off_t *’ {aka ‘long long int *’}
ssize_t* off_out,
src/unix/fs.c: In function ‘uv__fs_copyfile’:
src/unix/fs.c:1223:20: warning: comparison of integer expressions of different signedness: ‘__fsword_t’ {aka ‘int’} and ‘unsigned int’ [-Wsign-compare]
if (s.f_type != /* CIFS */ 0xFF534D42u)
CC src/unix/libuv_la-getnameinfo.lo
CC src/unix/libuv_la-loop-watcher.lo
CC src/unix/libuv_la-loop.lo
CC src/unix/libuv_la-pipe.lo
CC src/unix/libuv_la-poll.lo
CC src/unix/libuv_la-process.lo
CC src/unix/libuv_la-random-devurandom.lo
CC src/unix/libuv_la-signal.lo
CC src/unix/libuv_la-stream.lo
CC src/unix/libuv_la-tcp.lo
CC src/unix/libuv_la-thread.lo
CC src/unix/libuv_la-tty.lo
CC src/unix/libuv_la-udp.lo
CC src/unix/libuv_la-linux-core.lo
CC src/unix/libuv_la-linux-inotify.lo
CC src/unix/libuv_la-linux-syscalls.lo
CC src/unix/libuv_la-procfs-exepath.lo
CC src/unix/libuv_la-proctitle.lo
CC src/unix/libuv_la-random-getrandom.lo
CC src/unix/libuv_la-random-sysctl-linux.lo
CCLD libuv.la
building 'uvloop.loop' extension
creating build/temp.linux-armv7l-3.8
creating build/temp.linux-armv7l-3.8/uvloop
gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -fPIC -I/usr/local/include/python3.8 -I/tmp/pip-install-wevq14xd/uvloop_fa97f35bf09f412e9b2534726526384a/vendor/libuv/include -c uvloop/loop.c -o build/temp.linux-armv7l-3.8/uvloop/loop.o -O2
gcc: fatal error: Killed signal terminated program cc1
compilation terminated.
error: command 'gcc' failed with exit status 1
ERROR: Failed building wheel for uvloop
Running setup.py clean for uvloop
Failed to build uvloop
so i guess you use pip to upgrade AD in a venv?
you could try
pip install uvloop
I’m not using AD in a venv. I can install uvloop in user mode but not when sudoing.
so you got HA core and AD installed in 1 environment? (if so, thats bad)
you can use:
pip install uvloop,
but not
sudo pip install uvloop??
then dont do that. you also should not use
sudo pip install appdaemon,
but
HA is in a venv, not AD. never had any issue with AD before this. I know it is not related to AD directly. I’ll try to figure out
ah, thats ok then.
i guess uvloop has a problem when its installed with sudo. there are more libs that have that problem.
thats why its better also not to install AD with sudo.
i would uninstall AD 4.0.5 that you (if i understand it right) installed with sudo and then just use
Ok, AD documentation starts with:
Before running AppDaemon
you will need to install the package:
$ sudo pip3 install appdaemon
I’ll try to get some free time to do a reinstall
hmm, indeed you are right. its still in the docs.
i thought that was already taken out a long time ago.
@Odianosen25 can you change that for me?
I did an uninstall and reinstall as user and it works. I had to update AD service to match the new path. Strange thing is pip shows AD 4.0.8, but AD administration page shows 4.0.5. (full reboot and cache reset were made)
did you restart your device? (you say full reboot, so i guess so)
there are only 2 possibilities that the admin interface shows 4.0.5 while you are running 4.0.8
in the logs you also can see which version is running.
Indeed, one installation was still in /usr/local/lib/python3.7/dist-packages/appdaemon even if not listed by Pip (even in sudo). I removed it and updated the user in service definition to make it work. Now it says 4.0.8 in log and Administration page.
Thank you
