We have a few nice adds in this release, notably we now optionally support TOML for all configuration files, and Python 3.11 is officially supported. There is also a new optional mode for passing of **kwargs arguments in callbacks that removes some confusion in how AppDaemon originally implemented its callbacks - there for those that have wanted this for a while! We also have some scheduler fixes as well.
We will also be removing python 3.7 support soon as it goes end of life in a month or two.
- enjoy!
4.4.0
Features
AUI Now shows performance stats for plugin network access
New CI pipeline designed and configured by Carlo Mion
Add support for python 3.11
run_at() support for times that have already passed #1684
Add TOML Support
App endpoints now support the GET method
Many changes to docker image including update to Alpine py3 packages - contributed by Nigel Rook
Apps can now accept additional arguments using pythons native dictionary unpacking (** operator) instead of a dictionary
Rename parameters for the old kwargs mechanism to cb_args to make the distinction
Added type hints and a section on how to use with your IDE
Fixes
Trailing slash on hass url breaks connectivity #999
parse_time(“sunset”) and impact of “aware” #1645
constrain_person not working #1437
last_changed_seconds wrong due to timezone #1571
Fixed a long standing bug that caused some callbacks to be 1 hour early or later after a DST transition
Fixed an issue with sunset and sunrise based constraints on systems that use UTC instead of local timr that also affected
now_is_between()
This also fixed a long standing issue with sun_up() and sun_down()
Breaking Changes
Remove Python 3.7 test coverage prior to deprecation at EOL in 6/23
Register endpoint for async callbacks has been harmonized with the async version
Versioning note for 4.4.0 - This release was intended to be 4.3.0, however a problem with the new packaging pipeline blocked use of that version number on PyPi.
