Anonymous mqtt broker
Hi Folks,
i am desperate.
I need an anonymous mqtt broker, which does not in any way require username and password. I am aware of the security implications whatsoever, but i have dozens of (self-built) temperature sensors, that have no username and password configured. Updating them would force me to open up my walls and disassemble all light switches in my house, so this is not an option.
However: First I tried to use home-assistant addon mosquitto. It was not possible to disable authentication with custom mosquitto.conf (at least i found no way).
I also tried the (dirty hack) with ACL and “topic readwrite #”. This worked partially, but using some username/password for mqtt renders this useless as well.
Then i tried to build my own mosquitto-Addon for homeassistant.
I started by cloning the git-repository and modifying all possible files therein.
Copying the result into “/addons”-Folder, i was able to install my own version. Strangely, changes in config.yaml did show some effect (e.g. changing the name of the addon), but changing the files in “rootfs” did not, in any way.
What i tried was:
  • changing mosquitto.gtpl by commenting out all lines with “auth” in it
  • changing “Dockerfile” to not build mosquitto-auth-plugin.so
  • changing rootfs/etc/services.d/run so that only /share/mosquitto/mosquitto.conf is loaded
  • changing rootfs/etc/cont-init.d/mosquitto.sh so that no mosquitto.conf is generated by bashio, but my own is used
    ** This file is apparently not invoked in any way, because additional log output was not shown in the log
  • adding rootfs/etc/mosquitto/mosquitto.conf to be used by this container
I found out that changing the version-number in config.yaml has an effect on the docker-image which is pulled and executed, which was against my expectations, but anyway.
I am totally out of ideas.
Has anybody had this specific problem? How did you solve it?
If this still is relevant, it has to be easy as cake:
Isn’t installing mosquitto (or any other MQTT broker) on another device not an option?
If tou are really not concerned about security issues, there are cloud-based MQTT as well.
I wish it would be as easy as that…
Thanks for the link, it is a short summary of all the information pieces that i found in different places.
allow_anonymous true
was one of the first things i tried. This did not work.
The biggest problem i have is that there are no error messages whatsoever.
Using mosquitto_sub -h <ha-ip> - t "#" -v -d on one console and mosquitto_pub -h <ha-ip> -t "/test" -m 123 on the other just does not produce any output on the first one. It should on a correctly configured broker.
@koying I prefer having the broker inside my own network (reliability, privacy).
Using another device for running the broker is the last option, and i don’t really want to take this one.
I refuse to accept that it is impossible to run an anonymous broker on a home assistant os device. :slight_smile:
meanwhile i am beyond the point where i just want to have an anonymos mqtt broker - i really want to understand why none of the changes i did to the mqtt-addon have had any effect. :thinking:
Maybe use/look at the old addon:
That one allowed anonymous.
@koying Sadly, this does not work either:
The command '/bin/bash -o pipefail -c apk add --no-cache --virtual .build-dependencies git=2.24.1-r0 cmake=3.15.5-r0 build-base=0.5-r1 zlib-dev=1.2.11-r3 openssl-dev=1.1.1d-r3 && apk add --no-cache nginx=1.16.1-r6 lua-resty-http=0.15-r0 nginx-mod-http-lua=1.16.1-r6 && git clone --depth=1 https://github.com/hivemq/hivemq-mqtt-web-client.git /app && git checkout "${HIVEMQ}" && git clone --branch "v${LIBWEBSOCKETS}" --depth=1 https://github.com/warmcat/libwebsockets.git /tmp/libwebsockets && mkdir -p /tmp/libwebsockets/build && cd /tmp/libwebsockets/build && cmake .. -DCMAKE_BUILD_TYPE=MinSizeRel -DCMAKE_INSTALL_PREFIX=/usr -DLWS_IPV6=OFF -DLWS_WITHOUT_BUILTIN_GETIFADDRS=ON -DLWS_WITHOUT_CLIENT=ON -DLWS_WITHOUT_EXTENSIONS=ON -DLWS_WITHOUT_TESTAPPS=ON -DLWS_WITH_SHARED=OFF -DLWS_WITH_ZIP_FOPS=OFF -DLWS_WITH_ZLIB=OFF && make && make install && git clone --branch "v${MOSQUITTO}" --depth=1 https://github.com/eclipse/mosquitto.git /tmp/mosquitto && cd /tmp/mosquitto && make WITH_ADNS=no WITH_DOCS=no WITH_MEMORY_TRACKING=no WITH_TLS_PSK=no WITH_WEBSOCKETS=yes prefix=/usr binary && make WITH_DOCS=no install binary && addgroup -S mosquitto && adduser -S -D -H -h /var/empty -s /sbin/nologin -G mosquitto -g mosquitto mosquitto && apk del --no-cache --purge .build-dependencies && rm -fr /etc/nginx /opt/mosquitto.conf /opt/acl /tmp/*' returned a non-zero code: 54
I also tested to modify the /etc/mosquitto/mosquitto.conf file in the running docker image (of the official mosquitto addon). But after that the addon just won’t start and fail with an error “the docker image addon_local_mqtt” already exists" or something like that (cant recall it exactly atm).
The more i see i wonder why docker is so d*** complicated… :confused:
Hi fkzke,
were you able to solve this? I have a similar problem. A friend of mine did build a DIY wallbox in 2020. MQTT with no authentification was the solution to controll the wallbox. I would like to integrate this Wallbox in HA, with the embedde mqtt broker and ended up having the same problem. Core issue is, that my friend passed away last year and there is no way to change anything on the wallbox. So, the only way would be to get a broker with no authentification.
After the discussion i gave up, tried some different broker and installed emqx, which is also available as ha addon.
Emqx has a GUI and can be configured to also accept anonymous clients.
Still using it, works like a charm.
