Does anyone know how to change this template for the upcoming changes in 0.117.x
alias: Scan for arrive and depart
initial_state: "on"
- platform: homeassistant
event: start
- platform: state
entity_id: binary_sensor.entity_id_for_bt_scanning
to: "on"
condition:
condition: and
conditions:
- condition: template
value_template: "{{as_timestamp(as_local(states.sensor.time.last_changed)) - as_timestamp(state_attr('automation.scan_for_arrive_and_depart', 'last_triggered')) | float > 45 }}"
- service_template: >
{% if is_state('script.mqtt_arrive_depart_script', 'on') %}
script.turn_off
{% else %}
script.turn_on
{% endif %}
data_template:
entity_id: >
{% else %}
script.dummy
{% endif %}
- wait_template: "{{ is_state('script.dummy', 'off') }}"
- service: script.mqtt_arrive_depart_script
data_template:
# {"identity":"{{trigger.entity_id.split(".")[1]}} {{as_local(states.sensor.time.last_changed).strftime("%H:%M")}}"}
identity: >
{% if trigger.platform == 'state' %}
{"identity":"{{states("sensor.entity_id_for_bt_scanning")}} {{as_local(states.sensor.time.last_changed).strftime("%H:%M")}}"}}
{% else %}
{"identity":"HA-start {{as_local(states.sensor.time.last_changed).strftime("%H:%M")}}"}
{% endif %}
This is the error
Logger: homeassistant.components.automation.scan_for_arrive_and_depart
Source: components/mqtt/__init__.py:782
Integration: Automatisering (documentation, issues)
First occurred: 18:51:18 (2 occurrences)
Last logged: 18:51:18
Scan for arrive and depart: Error executing script. Unexpected error for call_service at pos 3: payload must be a string, bytearray, int, float or None.
While executing automation automation.scan_for_arrive_and_depart
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 253, in _async_step
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 463, in _async_call_service_step
await self._async_run_long_action(service_task)
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 422, in _async_run_long_action
long_task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1448, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1483, in _execute_service
await handler.job.target(service_call)
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 215, in service_handler
await script_entity.async_turn_on(
File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 320, in async_turn_on
await coro
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1010, in async_run
await asyncio.shield(run.async_run())
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 245, in async_run
await self._async_step(log_exceptions=False)
await getattr(
long_task.result()
task.result()
await coro
await getattr(
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 460, in _async_call_service_step
await service_task
task.result()
File "/usr/src/homeassistant/homeassistant/components/mqtt/__init__.py", line 581, in async_publish_service
await hass.data[DATA_MQTT].async_publish(msg_topic, payload, qos, retain)
File "/usr/src/homeassistant/homeassistant/components/mqtt/__init__.py", line 782, in async_publish
msg_info = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/local/lib/python3.8/site-packages/paho/mqtt/client.py", line 1259, in publish
raise TypeError(
TypeError: payload must be a string, bytearray, int, float or None.
Or this one?
alias: Unavailable entities sensor update
description: ""
- platform: time_pattern
minutes: /5
condition:
value_template: "{{ states('sensor.uptime_in_uren')|float > 0.05|float }}"
- variables:
entity_ids: |-
{{ states
| selectattr('state','in',['unavailable','unknown','none'])
| rejectattr('entity_id','in',state_attr('group.ignored_entities', 'entity_id'))
| rejectattr('domain','eq','group')
| map(attribute='entity_id')
| list
| join(',')
names: |-
{% set ns = namespace(names=[]) %}
{% for dev in entity_ids.split(',') %}
{% set ns.names = ns.names + [state_attr(dev, 'friendly_name')] %}
{% endfor %}
{{ ns.names | to_json }}
num: '{{ entity_ids.split(",") | length - 1 }}'
- service: mqtt.publish
topic: homeassistant/unavailable_entities
payload: |-
"num": {{ num }},
"names": {{ names }},
"entity_ids": {{ entity_ids.split(',') | to_json }}
error
Logger: homeassistant.components.automation.unavailable_entities_sensor_update
First occurred: 18:55:00 (4 occurrences)
Last logged: 19:00:00
Unavailable entities sensor update: Error executing script. Unexpected error for call_service at pos 2: payload must be a string, bytearray, int, float or None.
While executing automation automation.unavailable_entities_sensor_update
await getattr(
await service_task
task.result()
raise TypeError(
