Another climate related question
Hi all, I am attempting to create a blueprint that i can use to automate my 2 units. I have a bunch of code cobbled together from various sources, but need a push in the right direction (or someone to tell me its all fubar).
I want to be able to set the thermostat, morning time and evening time based on the blueprint and have it execute at those times based on what the daily high temperature is expected to be. i have an older uninsulated house and when its too hot or cold outside the thermostat needs to be adjusted to offset how it feels inside.
i believe the only thing i need to figure out is how to set the variables
            morning_temperature_heat:
            morning_temperature_cool:
            evening_temperature_heat:
            evening_temperature_cool:
but please let me know
blueprint:
  name: Climate Thermostat Schedule
  description: Set climate based on time of day and Daily high temperature
  domain: automation
  input:
    thermostat:
      description: Select the climate device to be used
      selector:
        entity:
          domain: climate
          multiple: false
    morning:
      description: Time morning schedule starts
      selector:
        time:
    evening:
      description: Time evening schedule starts
      selector:
        time:
    - choose:
      - conditions:
          - condition: numeric_state
            entity_id: sensor.openweathermap_forecast_temperature
            below: 65
            morning_temperature_heat: 73
            morning_temperature_cool: 75
            evening_temperature_heat: 70
            evening_temperature_cool: 74
          - condition:
            above: 65
            below: 80
            morning_temperature_heat: 72
            evening_temperature_heat: 67
            evening_temperature_cool: 70
          - condition:
            above: 80
            below: 95
            morning_temperature_heat: 65
            morning_temperature_cool: 76
          - condition:
            above: 95
            morning_temperature_cool: 77
            evening_temperature_heat: 65
            evening_temperature_cool: 69
    variables:
      thermostat: !input 'thermostat'
      morning_temp_heat: !input 'morning_temperature_heat'
      morning_temp_cool: !input 'morning_temperature_cool'
      evening_temp_heat: !input 'evening_temperature_heat'
      evening_temp_cool: !input 'evening_temperature_cool'
  - platform: time
    at: input_evening.morning_schedule
  - platform: time
    at: input_morning.evening_schedule
    condition: []
      - choose:
          - conditions:
              - condition: trigger
            sequence:
              - service: climate.set_temperature
                  entity_id: thermostat
                  target_temp_high: morning_temp_heat
                  hvac_mode: heat_cool
                  target_temp_low: morning_temp_cool
          - conditions:
            sequence:
                  target_temp_high: evening_temp_heat
                  target_temp_low: evening_temp_cool
        default: []
mode: single
SOLVED!
