With this blueprint we take over your heating.
You can set a minimum temperature value, If the
temperature is below this value it checks if somebody is home, And if that’s true
it will start heating to the value you set in the target temperature setting.
And you can set a time range, So that the climate device won’t start heating in the middle off the night.
Github Gist: https://gist.github.com/r3mcos3/5908a49fac1ea2e5332ae13ad2cd6fb3
blueprint:
description: Control your heating with options for person home, if temp is below a specific value, set temp, and heating between specific times.
domain: automation
input:
heating:
description: The climate device to use.
selector:
entity:
domain: climate
temp_sensor:
description: Temperature Sensor to check.
selector:
entity:
domain: sensor
device_class: temperature
person1:
description: The first person that has to be home.
default: []
selector:
entity:
domain: person
person2:
description: The second person that has to be home.
default: []
selector:
entity:
domain: person
min_temp:
description: If temperature is below this value and someone is home, It turns heating on.
default: 15
selector:
number:
min: 15
max: 25
step: 1
mode: slider
set_temp:
description: If the heating turns on, It heats to this target temperature.
default: 20
selector:
number:
min: 15
max: 25
step: 1
mode: slider
time_after:
description: After this time the heating turns on, so it's warm in the morning
default: '07:30:00'
selector:
time:
time_before:
description: After this time the heating turns off, This to prevent the heating is on in the middle of the night
default: '21:30:00'
selector:
time:
variables:
set_temp: !input set_temp
- platform: homeassistant
event: start
- platform: event
event_type: automation_reloaded
- platform: time_pattern
minutes: /10
- choose:
- conditions:
- condition: numeric_state
entity_id: !input 'temp_sensor'
below: !input min_temp
- condition: time
before: !input 'time_before'
after: !input 'time_after'
- condition: or
conditions:
- condition: state
entity_id: !input 'person1'
state: home
- condition: state
entity_id: !input 'person2'
state: home
sequence:
- service: climate.set_temperature
entity_id: !input 'heating'
hvac_mode: heat
temperature: "{{ set_temp }}"
default:
- service: climate.turn_off
mode: single
