Home.app Style templates for HomeAssistant
The main goal of this project is to provide a wide range of different templates that fit the “Home.app” style provided by Apple.
We are right now supporting the following entities domains:
alarms
binary_sensors
lights
media_players (sound & video)
switches
weather
Of course, this is not a 1to1 match to the “Home.app” style. We have took the idea, and implemented it in our way.
Keep in mind that this config ONLY WORKS on YAML mode
How to install it on HomeAssistant.
First of all, you need to install HACS, because we need some cards from there.
Once you have HACS installed, you need to install the following cards:
Clone this repo into the
config
folder on your HA installation -
Define the following lines on your lovelace
.yaml
file in which you are setting up your Lovelace UI (in my case,ui-lovelace.yaml
button_card_templates: !include_dir_merge_named homeapp-templates/templates/button-card
decluttering_templates: !include_dir_merge_named homeapp-templates/templates/decluttering-card
TODOs
- Implement more entities domains
- Support themes
- Support variations of the existings cards
- Order a little bit some messy parts of the code
- Try to get this PR approved to maximise customizability
Contribute
I would love to build a wide stardard templates that follows the “Home.app” style, so please! feel free to contribute!
To do it, you just need to clone the Github repo, create a PR, and that’s it!
It would be awesome!
Thanks!
I would also say thanks to every contributor and the authors of the resources that I’m using! Thanks guys!
Github Repo here: https://github.com/asierralozano/homeapp-templates
