Another Huawei solar integration option
Hi all,
For anyone that has a Huawei solar system - you know there’s many different integration options including
  • MODBUS TCP mode
  • ECHONET LITE
  • KIOSK MODE
  • NORTHBOUND API
  • Other custom integrations to get the smart meter data
  • Using circuit clamps
The only “easy” option to get return-to-grid and feed-in-from-grid data is the northbound API, but, at least for me, Huawei basically refused to create a northbound API account for. Also, this depends on the cloud and some people don’t like this.
So, if you have a smartlogger 3000 in your setup, i offer my own hacked integration that gets you feed in to grid and return to grid entities that you can use in the energy dashboard. Basically, I reverse engineered the authentication mechanism and grab the statistics from their API.
This is the setup
drop this in /config folder and change your password and ip address of smart logger. this first part extracts the data into a json object
curl -s -o /dev/null 'https://192.168.50.38/action/login' --data-raw 'langlist=0&usrname=admin&string=YOURPASSWORD&vercodeinput=&login=Log+In'   --compressed   --insecure --cookie-jar /var/tmp/cookies
curl -s 'https://192.168.50.38/js/csrf.jst' --compressed   --insecure  -b /var/tmp/cookies | grep "tokenObj.value = \"" | awk {'print $3'} | sed s/[\"\;]//g >/var/tmp/huawei.token
TOKEN=`cat /var/tmp/huawei.token`
curl -s "https://192.168.50.38/get_set_page_info.asp?type=88" -H "x-csrf-token: $TOKEN"  --compressed  --insecure -b /var/tmp/cookies | sed s/\|/\\n/g | awk -F~ '{printf "%s:%f\n", $3, $8}' | grep -v null | tail -n +2 | sed s/\\s/_/g | sed s/\'//g | sed s/\\//_/g | tr '[:upper:]' '[:lower:]' > /var/tmp/huawei.strings
jq -sR '[split("\n")[:-1][] | rtrimstr("\\r") | split (":") | {(.[0]): .[1]} ] | add' /var/tmp/huawei.strings
add this command-line script to your configurations.yaml
command_line:
    command: "/config/huawei.sh"
    json_attributes:
      - grid-tied_active_power
      - grid-tied_reactive_power
      - load_power
      - active_power
      - reactive_power
      - todays_power_supply_from_grid
      - current_day_supply_from_grid
      - current_day_feed-in_to_grid
      - current_day_consumption
      - total_power_supply_from_grid
      - total_supply_from_grid
      - total_feed-in_to_grid
      - total_power_consumption
      - pv_output_power
      - battery_charge_discharge_power
      - reactive_pv_power
      - reactive_ess_power
      - soc
      - current-day_charge_capacity
      - current-day_discharge_capacity
      - total_charge
      - total_discharge
      - rated_ess_power
    value_template: '{{ value_json.huawei }}'
add these sensors
template:
  - sensor:
       device_class: energy
       unit_of_measurement: "kWh"
       state: "{{ state_attr('sensor.huawei_command_line','grid-tied_active_power') }}"
  - sensor:
       device_class: power
       unit_of_measurement: "kW"
       state: "{{ state_attr('sensor.huawei_command_line','grid-tied_reactive_power') }}"
  - sensor:
       device_class: power
       state: "{{ state_attr('sensor.huawei_command_line','load_power') }}"
  - sensor:
       device_class: power
       state: "{{ state_attr('sensor.huawei_command_line','active_power') }}"
  - sensor:
       device_class: power
       state: "{{ state_attr('sensor.huawei_command_line','reactive_power') }}"
  - sensor:
       state: "{{ state_attr('sensor.huawei_command_line','todays_power_supply_from_grid') }}"
  - sensor:
       state: "{{ state_attr('sensor.huawei_command_line','current_day_supply_from_grid') }}"
  - sensor:
       state: "{{ state_attr('sensor.huawei_command_line','current_day_feed-in_to_grid') }}"
  - sensor:
       state: "{{ state_attr('sensor.huawei_command_line','current_day_consumption') }}"
  - sensor:
       state: "{{ state_attr('sensor.huawei_command_line','total_power_supply_from_grid') }}"
  - sensor:
       state_class: total_increasing
       state: "{{ state_attr('sensor.huawei_command_line','total_supply_from_grid') }}"
  - sensor:
       state: "{{ state_attr('sensor.huawei_command_line','total_feed-in_to_grid') }}"
  - sensor:
       state: "{{ state_attr('sensor.huawei_command_line','total_power_consumption') }}"
  - sensor:
       device_class: power
       state: "{{ state_attr('sensor.huawei_command_line','pv_output_power') }}"
  - sensor:
       device_class: power
       state: "{{ state_attr('sensor.huawei_command_line','battery_charge_discharge_power') }}"
  - sensor:
       device_class: power
       state: "{{ state_attr('sensor.huawei_command_line','reactive_pv_power') }}"
  - sensor:
       device_class: power
       state: "{{ state_attr('sensor.huawei_command_line','reactive_ess_power') }}"
  - sensor:
       device_class: battery
       unit_of_measurement: "%"
       state: "{{ state_attr('sensor.huawei_command_line','soc') }}"
  - sensor:
       state: "{{ state_attr('sensor.huawei_command_line','current-day_charge_capacity') }}"
  - sensor:
       state: "{{ state_attr('sensor.huawei_command_line','current-day_discharge_capacity') }}"
  - sensor:
       state: "{{ state_attr('sensor.huawei_command_line','total_charge') }}"
  - sensor:
       state: "{{ state_attr('sensor.huawei_command_line','total_discharge') }}"
  - sensor:
       device_class: power
       state: "{{ state_attr('sensor.huawei_command_line','rated_ess_power') }}"
it will expose these new sensors
Hello @mayberryjp
great work - does it work stable for you?
I have buyed a Smartlogger 3000 A01 EU for my Huawei inverters (3 as a cascade with one Luna battery) while Iam planed to add one or two Huawei inverters. But I use HomeAssistant and search for a smart way to integrate my inverters and battery in HA.
So I hope your solution will work when I will try to use it.
#mayberryjp
Can you help me?
I tried you hack, and return json with { “00” 0.0000 }
And in cookies file not found Token, just:
#HttpOnly_192.168.0.10 FALSE / TRUE 0 -webserver-session-0 ::webs.session::3b340fc640496703faa9ee78ebb9b85c
It’s a SmartLOgger 3000 ? My code still works for me above. Maybe you need to upgrade the smartlogger to the latest version? If you’ve done all that, then run each command one by one and paste the output. Also verify the username and password is correct
Hi! Just used your mod and it worked perfectly!
Now I have 2 questions. 1st, can I somehow add a sensor for current PV energy yeld?
Second, I have 3 inverters connected via modbus to the system. Is there a possibility, to get values from each inverter, or not?
#1 - it should be in there. huawei_command_active_power
#2 - not sure - log into your smart logger and see if it’s in your user interface for the smart logger. check this page → replace the url with your own IP: https://192.168.50.38/get_set_page_info.asp?type=88
if it’s there it’s just a matter of adding more to the yaml file
note - you may need to turn off the script while trying to log in. otherwise your log in and HA login will compete with each other
i’ve moved this to a docker capable container with mqtt now. it’s a better implementation. there’s a dockerfile for building an image and a docker compose file also in the repo
you can set 6 environment variables
HUAWEI_HOST
HUAWEI_PASSWORD
HUAWEI_USERNAME
MQTT_HOST
MQTT_PASSWORD
MQTT_USERNAME
Hi @mayberryjp I’m able to get the information with the commands line by line in SSH. But when creating the huawei.sh and adding the data to configuration.yaml, the sensors don’t fill in data.
I also saw about your new method via docker. Do you have instruction on how to build the image? Or are you able to convert this into a HomeAssistant add-on?
afbeelding
Go here
i don’t really like the HA add ons - its a lot of work and rules without much upside
look at the file named dockerfile
in Portainer, go to your docker host, go to images, build a new image
give the build a name. paste the contents of dockerfile in the build.
suggested image name → huawei_smart_logger_docker:v1.0.10
when its finished, go to stacks, add stack
give it a name - suggested name is huawei_smart_logger_docker
paste the contents of the file “compose”
compose has some example environment variables. you’ll want to set all of the environment variables below
HUAWEI_HOST=https://192.168.50.38
HUAWEI_PASSWORD=
HUAWEI_USERNAME=admin
MQTT_HOS =192.168.x.x
MQTT_PASSWORD=
MQTT_USERNAME=
this shold take about 5 minutes in total to get up and running
can view the logs to see any errors
i only use portainer so not sure how to use docker from command line - but im sure if you’re familiar with the command line then you can figure it out based on the dockerfile and compose
if anyone is using this - i pushed a new update to increase reliability of sensor delivery on mqtt. there’s a new dockerfile and compose in the repo
Cool thanks for the reply, I will first need to move our HA to a Proxmox host and it’s own VM. Will give me the ability to run multiple VM’s on the Intel NUC host.
I’ve been searching for solutions to integrate the SmartLogger3000, but it seems that this is the only option. I have Home Assistant installed on a Raspberry Pi 5, but I don’t have a separate Docker instance in Portainer. Do I need to reinstall everything, first setting up Docker and then installing Home Assistant?
I used your first solution and not the Docker one, and it works perfectly.
