Hi. I’ve managed to partially fix my sync between input_select and MQTT.
- alias: Set Central Heating Temporary Mode
initial_state: on
- platform: state
entity_id: input_select.central_heating_temporary_mode
- service: mqtt.publish
data_template:
topic: "ebusd/f47/Hc1SFMode/set"
payload: >
{% set tpmode = {
'None': 'none',
'Day away': 'onedayholiday',
'Day in': 'onedaybankholiday',
'Party': 'party' } %}
{{ tpmode.get(trigger.to_state.state,'none') }}
- alias: Get Central Heating Temporary Mode
initial_state: on
- platform: mqtt
topic: "ebusd/f47/Hc1SFMode"
service: input_select.select_option
data_template:
option: >
{% set tpmode = {
'none': 'None',
'onedayholiday': 'Day away',
'onedaybankholiday': 'Day in',
'party': 'Party' } %}
{{ tpmode.get('trigger.payload','None') }}
Technically this is working fine, but when I change the input_select in HA, as soon as ithe message is sent to ebusd/f47/Hc1SFMode/set, “Get Central Heating Temporary Mode” automation is triggered with the old value (why? ebusd/f47/Hc1SFMode/ has not changed yet), input_select is changed back to the original value, and “Set Central Heating Temporary Mode” is triggered again sending the original value to ebusd/f47/Hc1SFMode/set. So while i can see the topics changing on MQTT side, its almost instantly changed back.
If i disable “Get Central Heating Temporary Mode” automation, then “Set Central Heating Temporary Mode” works fine and changes ebusd/f47/Hc1SFMode correctly.
Im using similar automations with input_numbers and they work perfectly fine and im not sure why input_select behaves differently:
- alias: Set Central Heating Heat Curve
initial_state: on
- platform: state
entity_id: input_number.central_heating_heat_curve
data_template:
topic: "ebusd/f47/Hc1HeatCurve/set"
payload: "{{ states.input_number.central_heating_heat_curve.state | float }}"
- alias: Get Central Heating Heat Curve
initial_state: on
- platform: mqtt
topic: "ebusd/f47/Hc1HeatCurve"
service: input_number.set_value
data_template:
value: "{{ trigger.payload | float }}"
