I’ve seen this message occur many times when searching here, but each case seems different.
I want to reset my modem (which tends to act up after a while… it’s a ISP-provided modem-router, and it just serves as a modem, I have proper routers in the house). This is my first true automation, after testing a few easy things I figured it would be easy to use a smart plug, turn it off once a month, wait 15 seconds then turn it back on.
I plowed through the UI, no dice, tried my hand at NodeRED (even asking ChatGPT to help, which gave me inaccurate directions), then looked at a lot of YAML examples. I believe I’ve got something which works, but each time I try to save it, the UI asks me for a name for the automation, then tells me “Message malformed: extra keys not allowed @ data[‘0’]”.
I can’t figure out what I did wrong, and it seems simple enough. For the record, I was trying on another, less mission-critical plug at the time, figuring if it works I’ll just replace the automation with the proper plug. Here’s my rather simple YAML code:
alias: Eteindre routeur une fois par mois
Thanks. That didn’t work, sadly. Here’s (I hope" a better formatting of the current code
- alias: Eteindre routeur une fois par mois
- platform: time
at: '17:10:30'
condition:
- condition: template
# Change the number here to get whatever day of the month you want.
value_template: "{{ now().day == 8 }}"
actions:
sequence:
- service: switch.turn_off
entity_id: switch.prise_ecran_bernard
- delay: 15
- service: switch.turn_on
Still no dice. I followed the advice by tom_l. Here’s what I have.
- platform: time
at: '17:10:30'
condition:
actions:
- action: switch.turn_off
- delay: 15
- action: switch.turn_on
@d921 : this is my first post. Please be tolerant. I fixed the formatting in my next reply. And I did explain what I want to do : once per month, turn off the router for 15 seconds, then turn it back on. I’m open to any suggestion to make it work, I haven’t found a way using the UI or NodeRED.
@tom_l still getting “Message malformed: extra keys not allowed @ data[‘0’]” when trying to save the automation (after giving it a name). It won’t let me save it.
My YAML is currently:
- platform: time
at: '17:10:30'
condition:
actions:
- delay: 15
@d921 I’m not yet able to test it since I can’t save it. It is intended to run at a given time. Once I can save it, I’ll use a plug near me (the one used in my YAML) and test by updating the time to whatever’s current. Then once I know it works, I’ll replace the plug with the modem’s plug, and the time with what I want it to be in the future.
I tried creating a new automation. I get the UI, then click the three dots, “Modify in YAML”. I’m using the code we’ve been discussing, then at the bottom right there’s a blue “Save” button (mine’s in French, it might say a synonym of “save”). It then asks for a name, and when I click “Save” in that new window, I get the error message I shared.
EDIT: I listened to my teenager and asked Chat GPT to correct the code. It came up with this, which worked:
- platform: time
at: '17:10:30'
condition:
- delay: "00:00:15"
It had me revert to “service” instead of “action”, saying it’s the “correct” wording. I pasted it in the HA editor and boom, I got a working automation. Go figure.
Thanks for the useful discussion! I still don’t know what changed, indentation and other stuff doesn’t seem to have changed (apart from the dash before “alias” ).
