@fmon Great to here. Just to clarify, are you using Hass.io
or Hassbian
? It doesn’t matter if it’s working, just net to know.
Regarding the accessory_driver.py
file. It didn’t change with the update to (0.80) so you should still be running the modified version. Would you like to try if paring would work with the original version as well? The steps to do would be:
- Unpair, maybe change the filter config (to
demo.demo
) - Stop Home Assistant
- Rename current file to
accessory_driver-working.py
or sth similar - Download the original one here: link or use the local one if you still have that
- Start Home Assistant
- Try pairing
