I am looking for some help regarding a switch template and the subsequent switch state.
I am no programmer and have pieced bits together to create a switch from a template that runs two scripts, the first turns on the console including TV, Soundbar, Sky box and sets the channel to a set channel. Many of these items are switched on via IR using a broadlink RM Pro. The second script switches everything off.
So I have a switch template, input boolean and the scripts.
What I am trying to do is tidy up my dashboard using entity mushroom cards, with the icon colour changing when the state changes from off to on. The problem I have is that by default the switch state is on and regardless of whether the switch is on or off it never changes. I tested the icon changing by setting the state in the developer tools section. However with the switch it leaves the icon lit on the dashboard. Is there any way to change the switch state to off when the off script is triggered and on when the on script is run.
The switch works other than the state changing. Please go easy on me as I’m miles out of my depth here.
The code is as follows:
In boolean.yaml
entertainment:
initial: on
In broadlink.yaml (my switches)
switches:
console:
value_template: "{% if is_state('input_boolean.entertainment', 'on') %}on{% else %}off{% endif %}"
turn_on:
service: script.turn_on
entity_id: script.console_on
turn_off:
entity_id: script.1577541085737
This is my console on script as an example
alias: Console On
sequence:
- condition: state
entity_id: switch.sonoff_100184f911
state: "off"
- service: switch.turn_on
data: {}
entity_id:
- switch.sonoff_100184f911
- delay:
hours: 0
minutes: 0
seconds: 3
milliseconds: 0
data: {}
entity_id: switch.curve
data: {}
entity_id: switch.hdmi_1
- delay:
hours: 0
minutes: 1
seconds: 45
milliseconds: 0
- service: remote.send_command
device: Stream
command: power
delay_secs: 0.9
entity_id: remote.broadlink3
enabled: true
- delay:
hours: 0
minutes: 0
seconds: 5
milliseconds: 0
device: Stream
command: left
delay_secs: 1
enabled: true
device: Stream
command: select
delay_secs: 1
enabled: true
device: Stream
command: 3
delay_secs: 1
enabled: true
- delay:
hours: 0
minutes: 0
seconds: 3
milliseconds: 0
enabled: true
data: {}
entity_id: switch.sky_cooling_fans
- delay:
hours: 0
minutes: 0
seconds: 1
milliseconds: 0
enabled: true
data: {}
entity_id: switch.sound
enabled: true
mode: single
icon: mdi:power-cycle
Thanks for any advice/help.
Paul.
