Another Tado blueprint with external secondary temp sensor for offset adjustment
Hey folks!
I’m thrilled to share my Tado Temperature Offset blueprint—initally inspired by Sanderma’s template (big thanks to them!). Like all others, this automation helps keep Tado’s reported temperature aligned with a secondary sensor, ensuring more accurate readings and a happier home… but with sensible adjustments resulting in fewer re-calibration service calls.
Why You Need This Blueprint
  1. No More Wonky Readings
    If your Tado is a bit off compared to your actual room temperature, let this blueprint calculate and apply an offset so everything lines up nicely.
  2. Configurable Persistence
    Both Tado and your secondary sensor need to hold their temperatures for N minutes before any offset changes happen—meaning fewer tiny blips causing big changes. (Yes, you can tweak the time to fit your preference.) This gives your radiator time to heat the room and reach your secondary sensor.
  3. “Is It Really Different?”
    There’s a ±0.5°C (by default) gap check in place, so the blueprint only adjusts the offset if the difference actually matters. Prevent excessive service calls and Tado battery drain.
  4. Hysteresis
    Because we like things calm and cool, I’ve introduced hysteresis to avoid back-and-forth recalculations. Say goodbye to constant offset ping-ponging! This allows for a configurable ‘gap’ between sensor A & B to exist as the room heats. Again, preventing excessive service calls and extending battery life.
  5. Lots of Debug Logging
    Get a step-by-step log for every offset calculation and event trigger if you love digging into the nerdy details.
Hello clausd84,
Thanks for contributing to the community with a new Blueprint.
I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
Hi @Sir_Goodenough thanks for the link creator. I’ll make sure I save that :slight_smile:
Nice work Claus, I’ve been using another blueprint but yours has some nice improvements so I’ll be switching to yours at the weekend. Thank you!
Hey thanks for the amazing work, I really like your blueprint. One thing that could be improved though is adding one optional check to only trigger the automation when the target room is heating, this way you avoid changing the offset without need which drains battery life of the thermostat
I like this blueprint, the only downside is that the TRV seems to be doing what sounds like calibration every couple of minutes, even with the persistence times set to 5 minutes. How come the TRV needs to do this? Is it part of Tado’s offset behaviour?
Many thanks
