Hi everyone!
I’ve been trying to make this sensor work properly with ZHA. ( Full name on aliexpress is Zigbee Mmwave Human Presence Sensor Tuya Presence Detector Smart Home Automation Motion Distance Sensor For Smart Life App )
The only custom quirks that makes it partially working is the following (attached at the bottom), adding _TZE204_mhxn2jso on this class:
class TuyaMmwRadarOccupancyVariant2(CustomDevice):
"""Mini/Ceiling Human Breathe Sensor"""
With this, I can see all the settings available… It was sorta-of working at the beginning, but after playing around with the calibration it got stuck in Occupancy Detected
, no matter the settings I’m using. It could be I’ve got a defective sensor, but since nobody else is using this _TZE204_mhxn2jso yet, it might just be a wrong quirks configuration.
Here’s the full custom quirks
"""BlitzWolf IS-3/Tuya motion rechargeable occupancy sensor."""
import math
from typing import Dict, Optional, Tuple, Union
from zigpy.profiles import zgp, zha
from zigpy.quirks import CustomDevice
import zigpy.types as t
from zigpy.zcl import foundation
from zigpy.zcl.clusters.general import (
AnalogInput,
AnalogOutput,
Basic,
GreenPowerProxy,
Groups,
Identify,
Ota,
Scenes,
Time,
from zigpy.zcl.clusters.measurement import (
IlluminanceMeasurement,
OccupancySensing,
RelativeHumidity,
TemperatureMeasurement,
from zigpy.zcl.clusters.security import IasZone
from zhaquirks import Bus, LocalDataCluster, MotionOnEvent
from zhaquirks.const import (
DEVICE_TYPE,
ENDPOINTS,
INPUT_CLUSTERS,
MODELS_INFO,
MOTION_EVENT,
OUTPUT_CLUSTERS,
PROFILE_ID,
from zhaquirks.tuya import (
NoManufacturerCluster,
TuyaLocalCluster,
TuyaManufCluster,
TuyaNewManufCluster,
from zhaquirks.tuya.mcu import (
DPToAttributeMapping,
TuyaAttributesCluster,
TuyaMCUCluster,
ZONE_TYPE = 0x0001
class TuyaMmwRadarSelfTest(t.enum8):
"""Mmw radar self test values."""
TESTING = 0
TEST_SUCCESS = 1
TEST_FAILURE = 2
OTHER = 3
COMM_FAULT = 4
RADAR_FAULT = 5
class TuyaOccupancySensing(OccupancySensing, TuyaLocalCluster):
"""Tuya local OccupancySensing cluster."""
class TuyaAnalogInput(AnalogInput, TuyaLocalCluster):
"""Tuya local AnalogInput cluster."""
class TuyaIlluminanceMeasurement(IlluminanceMeasurement, TuyaLocalCluster):
"""Tuya local IlluminanceMeasurement cluster."""
class TuyaTemperatureMeasurement(TemperatureMeasurement, TuyaLocalCluster):
"""Tuya local TemperatureMeasurement cluster."""
class TuyaRelativeHumidity(RelativeHumidity, TuyaLocalCluster):
"""Tuya local RelativeHumidity cluster."""
class TuyaMmwRadarSensitivity(TuyaAttributesCluster, AnalogOutput):
"""AnalogOutput cluster for sensitivity."""
_CONSTANT_ATTRIBUTES = {
AnalogOutput.AttributeDefs.description.id: "sensitivity",
AnalogOutput.AttributeDefs.min_present_value.id: 1,
AnalogOutput.AttributeDefs.max_present_value.id: 9,
AnalogOutput.AttributeDefs.resolution.id: 1,
class TuyaMmwRadarMinRange(TuyaAttributesCluster, AnalogOutput):
"""AnalogOutput cluster for min range."""
AnalogOutput.AttributeDefs.description.id: "min_range",
AnalogOutput.AttributeDefs.min_present_value.id: 0,
AnalogOutput.AttributeDefs.max_present_value.id: 950,
AnalogOutput.AttributeDefs.resolution.id: 10,
AnalogOutput.AttributeDefs.engineering_units.id: 118, # 31: meters
class TuyaMmwRadarMaxRange(TuyaAttributesCluster, AnalogOutput):
"""AnalogOutput cluster for max range."""
AnalogOutput.AttributeDefs.description.id: "max_range",
AnalogOutput.AttributeDefs.min_present_value.id: 10,
class TuyaMmwRadarDetectionDelay(TuyaAttributesCluster, AnalogOutput):
"""AnalogOutput cluster for detection delay."""
AnalogOutput.AttributeDefs.description.id: "detection_delay",
AnalogOutput.AttributeDefs.min_present_value.id: 000,
AnalogOutput.AttributeDefs.max_present_value.id: 20000,
AnalogOutput.AttributeDefs.resolution.id: 100,
AnalogOutput.AttributeDefs.engineering_units.id: 159, # 73: seconds
class TuyaMmwRadarFadingTime(TuyaAttributesCluster, AnalogOutput):
"""AnalogOutput cluster for fading time."""
AnalogOutput.AttributeDefs.description.id: "fading_time",
AnalogOutput.AttributeDefs.min_present_value.id: 2000,
AnalogOutput.AttributeDefs.max_present_value.id: 200000,
AnalogOutput.AttributeDefs.resolution.id: 1000,
class TuyaMmwRadarTargetDistance(TuyaAttributesCluster, AnalogInput):
"""AnalogInput cluster for target distance."""
AnalogOutput.AttributeDefs.description.id: "target_distance",
class NeoBatteryLevel(t.enum8):
"""NEO battery level enum."""
BATTERY_FULL = 0x00
BATTERY_HIGH = 0x01
BATTERY_MEDIUM = 0x02
BATTERY_LOW = 0x03
USB_POWER = 0x04
class NeoMotionManufCluster(TuyaNewManufCluster):
"""Neo manufacturer cluster."""
attributes = TuyaNewManufCluster.attributes.copy()
attributes.update(
0xEF0D: ("dp_113", t.enum8, True), # ramdom attribute ID
dp_to_attribute: Dict[int, DPToAttributeMapping] = {
101: DPToAttributeMapping(
TuyaOccupancySensing.ep_attribute,
"occupancy",
104: DPToAttributeMapping(
TuyaTemperatureMeasurement.ep_attribute,
"measured_value",
lambda x: x * 10,
105: DPToAttributeMapping(
TuyaRelativeHumidity.ep_attribute,
"measured_value",
lambda x: x * 100,
113: DPToAttributeMapping(
TuyaNewManufCluster.ep_attribute,
"dp_113",
data_point_handlers = {
101: "_dp_2_attr_update",
104: "_dp_2_attr_update",
105: "_dp_2_attr_update",
113: "_dp_2_attr_update",
class TuyaMmwRadarClusterBase(NoManufacturerCluster, TuyaMCUCluster):
"""Mmw radar cluster, base class."""
attributes = TuyaMCUCluster.attributes.copy()
attributes.update(
# ramdom attribute IDs
0xEF01: ("occupancy", t.uint32_t, True),
0xEF02: ("sensitivity", t.uint32_t, True),
0xEF03: ("min_range", t.uint32_t, True),
0xEF04: ("max_range", t.uint32_t, True),
0xEF06: ("self_test", TuyaMmwRadarSelfTest, True),
0xEF09: ("target_distance", t.uint32_t, True),
0xEF65: ("detection_delay", t.uint32_t, True),
0xEF66: ("fading_time", t.uint32_t, True),
0xEF67: ("cli", t.CharacterString, True),
0xEF68: ("illuminance", t.uint32_t, True),
class TuyaMmwRadarClusterV1(TuyaMmwRadarClusterBase):
"""Mmw radar cluster, variant 1."""
"occupancy",
2: DPToAttributeMapping(
TuyaMmwRadarSensitivity.ep_attribute,
"present_value",
TuyaMmwRadarMinRange.ep_attribute,
"present_value",
endpoint_id=2,
TuyaMmwRadarMaxRange.ep_attribute,
"present_value",
endpoint_id=3,
6: DPToAttributeMapping(
TuyaMCUCluster.ep_attribute,
"self_test",
9: DPToAttributeMapping(
TuyaMmwRadarTargetDistance.ep_attribute,
"present_value",
lambda x: x / 100,
TuyaMmwRadarDetectionDelay.ep_attribute,
"present_value",
converter=lambda x: x * 100,
dp_converter=lambda x: x // 100,
endpoint_id=4,
102: DPToAttributeMapping(
TuyaMmwRadarFadingTime.ep_attribute,
"present_value",
endpoint_id=5,
103: DPToAttributeMapping(
"cli",
TuyaIlluminanceMeasurement.ep_attribute,
"measured_value",
converter=lambda x: int(math.log10(x) * 10000 + 1) if x > 0 else int(0),
2: "_dp_2_attr_update",
6: "_dp_2_attr_update",
9: "_dp_2_attr_update",
102: "_dp_2_attr_update",
103: "_dp_2_attr_update",
class TuyaMmwRadarClusterV2(TuyaMmwRadarClusterBase):
"""Mmw radar cluster, variant 2."""
"occupancy",
"present_value",
"present_value",
endpoint_id=2,
"present_value",
endpoint_id=3,
"present_value",
"present_value",
endpoint_id=4,
"present_value",
endpoint_id=5,
"measured_value",
class TuyaMmwRadarClusterV3(TuyaMmwRadarClusterBase):
"""Tuya MMW radar cluster, variant 3."""
"cli",
"measured_value",
"occupancy",
106: DPToAttributeMapping(
"present_value",
107: DPToAttributeMapping(
"present_value",
endpoint_id=3,
108: DPToAttributeMapping(
"present_value",
endpoint_id=2,
109: DPToAttributeMapping(
"present_value",
110: DPToAttributeMapping(
"present_value",
endpoint_id=5,
111: DPToAttributeMapping(
"present_value",
endpoint_id=4,
106: "_dp_2_attr_update",
107: "_dp_2_attr_update",
108: "_dp_2_attr_update",
109: "_dp_2_attr_update",
110: "_dp_2_attr_update",
111: "_dp_2_attr_update",
class MotionCluster(LocalDataCluster, MotionOnEvent):
"""Tuya Motion Sensor."""
_CONSTANT_ATTRIBUTES = {ZONE_TYPE: IasZone.ZoneType.Motion_Sensor}
reset_s = 15
class TuyaManufacturerClusterMotion(TuyaManufCluster):
"""Manufacturer Specific Cluster of the Motion device."""
def handle_cluster_request(
self,
hdr: foundation.ZCLHeader,
args: Tuple[TuyaManufCluster.Command],
dst_addressing: Optional[
Union[t.Addressing.Group, t.Addressing.IEEE, t.Addressing.NWK]
] = None,
) -> None:
"""Handle cluster request."""
tuya_cmd = args[0]
self.debug("handle_cluster_request--> hdr: %s, args: %s", hdr, args)
if hdr.command_id == 0x0001 and tuya_cmd.command_id == 1027:
self.endpoint.device.motion_bus.listener_event(MOTION_EVENT)
class TuyaMotion(CustomDevice):
"""BW-IS3 occupancy sensor."""
def __init__(self, *args, **kwargs):
"""Init device."""
self.motion_bus = Bus()
super().__init__(*args, **kwargs)
signature = {
# endpoint=1 profile=260 device_type=0 device_version=0 input_clusters=[0, 3]
# output_clusters=[3, 25]>
MODELS_INFO: [("_TYST11_i5j6ifxj", "5j6ifxj"), ("_TYST11_7hfcudw5", "hfcudw5")],
ENDPOINTS: {
1: {
PROFILE_ID: zha.PROFILE_ID,
DEVICE_TYPE: zha.DeviceType.ON_OFF_SWITCH,
INPUT_CLUSTERS: [Basic.cluster_id, Identify.cluster_id],
OUTPUT_CLUSTERS: [Identify.cluster_id, Ota.cluster_id],
replacement = {
ENDPOINTS: {
1: {
DEVICE_TYPE: zha.DeviceType.OCCUPANCY_SENSOR,
INPUT_CLUSTERS: [
Basic.cluster_id,
MotionCluster,
TuyaManufacturerClusterMotion,
class NeoMotion(CustomDevice):
"""NAS-PD07 occupancy sensor."""
signature = {
# endpoint=1 profile=260 device_type=81 device_version=0 input_clusters=[0, 4, 5, 61184]
# output_clusters=[10, 25]>
MODELS_INFO: [
("_TZE200_7hfcudw5", "TS0601"),
("_TZE200_ppuj1vem", "TS0601"),
ENDPOINTS: {
1: {
DEVICE_TYPE: zha.DeviceType.SMART_PLUG,
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
NeoMotionManufCluster.cluster_id,
OUTPUT_CLUSTERS: [Time.cluster_id, Ota.cluster_id],
replacement = {
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
NeoMotionManufCluster,
TuyaOccupancySensing,
TuyaTemperatureMeasurement,
TuyaRelativeHumidity,
class TuyaMmwRadarOccupancyVariant1GPP(CustomDevice):
"""Millimeter wave occupancy sensor."""
signature = {
# endpoint=1, profile=260, device_type=81, device_version=1,
# input_clusters=[4, 5, 61184, 0], output_clusters=[25, 10])
MODELS_INFO: [
("_TZE200_ar0slwnd", "TS0601"),
("_TZE200_sfiy5tfs", "TS0601"),
("_TZE200_mrf6vtua", "TS0601"),
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
TuyaNewManufCluster.cluster_id,
242: {
# <SimpleDescriptor endpoint=242 profile=41440 device_type=97
# input_clusters=[]
# output_clusters=[33]
PROFILE_ID: zgp.PROFILE_ID,
DEVICE_TYPE: zgp.DeviceType.PROXY_BASIC,
INPUT_CLUSTERS: [],
OUTPUT_CLUSTERS: [GreenPowerProxy.cluster_id],
replacement = {
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
TuyaMmwRadarClusterV1,
TuyaAnalogInput,
TuyaIlluminanceMeasurement,
242: {
INPUT_CLUSTERS: [],
class TuyaMmwRadarOccupancyVariant1(CustomDevice):
signature = {
# input_clusters=[0, 4, 5, 61184], output_clusters=[25, 10]
MODELS_INFO: [
("_TZE200_ztc6ggyl", "TS0601"),
("_TZE204_ztc6ggyl", "TS0601"),
("_TZE200_wukb7rhc", "TS0601"),
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
replacement = {
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
TuyaMmwRadarTargetDistance,
TuyaMmwRadarSensitivity,
2: {
DEVICE_TYPE: zha.DeviceType.COMBINED_INTERFACE,
INPUT_CLUSTERS: [
TuyaMmwRadarMinRange,
OUTPUT_CLUSTERS: [],
3: {
INPUT_CLUSTERS: [
TuyaMmwRadarMaxRange,
4: {
INPUT_CLUSTERS: [
TuyaMmwRadarDetectionDelay,
5: {
INPUT_CLUSTERS: [
TuyaMmwRadarFadingTime,
signature = {
MODELS_INFO: [
("_TZE204_qasjif9e", "TS0601"),
("_TZE204_mhxn2jso", "TS0601"),
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
242: {
# <SimpleDescriptor endpoint=242, profile=41440, device_type=97, device_version=0, input_clusters=[], output_clusters=[33]
# input_clusters=[]
INPUT_CLUSTERS: [],
replacement = {
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
TuyaMmwRadarClusterV2,
2: {
INPUT_CLUSTERS: [
3: {
INPUT_CLUSTERS: [
4: {
INPUT_CLUSTERS: [
5: {
INPUT_CLUSTERS: [
242: {
INPUT_CLUSTERS: [],
class TuyaMmwRadarOccupancyVariant3(CustomDevice):
signature = {
# input_clusters=[0, 4, 5, 61184], output_clusters=[25, 10])
MODELS_INFO: [
("_TZE204_sxm7l9xa", "TS0601"),
("_TZE204_e5m9c5hl", "TS0601"),
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
242: {
# input_clusters=[]
INPUT_CLUSTERS: [],
replacement = {
ENDPOINTS: {
1: {
INPUT_CLUSTERS: [
Basic.cluster_id,
Groups.cluster_id,
Scenes.cluster_id,
TuyaMmwRadarClusterV3,
2: {
INPUT_CLUSTERS: [
3: {
INPUT_CLUSTERS: [
4: {
INPUT_CLUSTERS: [
5: {
INPUT_CLUSTERS: [
242: {
INPUT_CLUSTERS: [],
Cheers!
