vt220
September 18, 2022, 8:35am
1
I have an anoying problem with home assistant auto discovery and my tv (Hisense).
Everytime I power up the TV Homeassistant detects a new DLNA Device. I don’t want to use that.
So at the end of a day I have the TV detected 4 or 5 Times sperately und I cann 4-5 times click on ignore device. After browsing the forum, I tried to add the following to my configuration.yaml
discovery:
ignore:
-dlna_dmr
It doesnt sadly have any effects…
Any idead on that matter?
Thx a lot…
vt220
October 21, 2022, 6:19am
4
Yeah, really nothing new on that Matter?
Mine did it for a while too. Instead of letting it get under your skin and repeatedly going through the discovery and ignore routine, why don’t you just integrate it and leave it? Surely seeing those DLNA devices won’t be the end of the world.
vt220
November 5, 2022, 9:49am
6
Yeah. Ill try that and hope it doenst rediscover everyime the IP of the TV changes…
could you elaborate on “integrate it”?
There is configure
and ignore
, which ever one we click, it comes back after a reboot. So many complaints about this
opened 01:54PM - 17 Jun 22 UTC
closed 06:40PM - 11 Dec 22 UTC
integration: dlna_dmr
### The problem
![discovery](https://user-images.githubusercontent.com/21245147… /174311018-fa1922cb-9eea-430a-82b8-86c1c4fff279.jpeg)
I ignored like 40 Discoveries for the same devices of this Integration, it keeps discovering, though.
Most of them are from Hisense VIDAA TV. AVM FRITZ!Mediaserver, 50PUS6162/12 and Samsung do discovery as well though.
It's pretty annoying as I'm not using this Integration and not planing too.
Similar issue was already "fixed" in #56898
### What version of Home Assistant Core has the issue?
2022.6.5
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant Container
### Integration causing the issue
DLNA Digital Media Renderer
### Link to integration documentation on our website
https://www.home-assistant.io/integrations/dlna_dmr
### Diagnostics information
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
opened 02:23PM - 01 Oct 21 UTC
closed 03:11PM - 31 Oct 21 UTC
### The problem
![image](https://user-images.githubusercontent.com/195327/135… 635824-1c1902d3-c09b-4ce0-a3d6-79b6a39aa51c.png)
I have quite a few media receivers in my home that support DLNA DMR. Which causes the integration to bring up / discover quite a bunch of devices.
This is really unwished for, and in all cases, an better integration is available in Home Assistant.
As an example, each of my Sonos speakers throughout the house is detected, while they really should be used using the Sonos integration instead (see screenshot above).
Therefore, I think the integration will harm the end-user experience with the current discovery in place. For example, a new user installing Home Assistant with a similar experience will be flooded with DLNA discovered items, while they most likely don't need them (or a better alternative is available). Also for existing users (upgrading or installing new devices), this is not wished for.
For the above reasoning: I suggest removing the SSDP discovery from the DLNA Digital Media Renderer integration (before the beta of 2021.10 ends).
### What is version of Home Assistant Core has the issue?
core-2021.10.b0
core-2021.9.7
Home Assistant Supervised
_No response_
_No response_
_No response_
