My Netatmo Thermostat Integration in Home Assistant loses serval times per day connection with the relay.
Sometimes the relay is offline so that would be obvious, but more often it isn’t and I can connect to the thermostat with the Netatmo website.
If I restart Home Assistant than the thermostat is up and running again. Anybody knows what could be the problem?
Nevermind. I saw this comment: Netatmo is suddenly dead - #15 by cgtobi
I’ll be patient.
@cgtobi Has progress been made to address this issue?
Yes, a solution has been implemented and is submitted for review. Meanwhile a custom component is available via HACS. But, this custom component is explicitly marked as beta and is not meant as a production replacement.
