Hi there!
New to this forum and trying to set up home assistant (hass-io on rpi3). I have got most things set up and working however I have run into problems with my receiver which is a Anthem MRX-520.
I was following the instructions on here and updated my configuration.yaml file with the following:
media_player:
- platform: anthemav
host: 192.168.13.63
port: 14999
What works:
I can then from within hassio switch outputs and control volume or turn it on/off. If I turn off the receiver using my harmony remote it will switch state to being OFF.
The problem:
Once it is off. Hassio doesn’t recognize it if I turn the receiver on using my remote. Only using the power toggle from within hassio will make it turn the state on. However if I reboot hassio with the receiver on it will recognize it as ON.
Why doesn’t it recognize it powering on from remote?
The receiver has a fixed IP on my router so it’s always the same (the receiver itself has DHCP if that matters?). I have made sure standby IP control is on.
I saw that it’s using the python anthemav module, do I need to install this, I thought this was already on the system? Any other suggestions to what could be wrong?
Thanks in advance!
