I saw that homeassistant has integration for ialarm. I tried to use it, but I can only activate the alarm, then I can no longer turn it off. I thank those who can help me.
According to the docs this platform supports the following services:
alarm_control_panel.alarm_arm_away
alarm_control_panel.alarm_arm_home
alarm_control_panel.alarm_disarm <--------------------
Rarely I can turn off the alarm, but then I can no longer turn it on and the status becomes “unavailable”
Sounds like you have connection issues. What do your logs say?
thank you for your help
Logger: homeassistant.components.ialarm
Source: components/ialarm/init.py:74
Integration: Antifurto365 iAlarm (documentation, issues)
First occurred: 20 giugno 2021, 18:15:55 (242 occurrences)
Last logged: 10:39:03
Unexpected error fetching ialarm data: ‘NoneType’ object has no attribute ‘get’
File “/usr/local/lib/python3.8/site-packages/pyialarm/pyialarm.py”, line 229, in _clean_response_dict
i = int(i)
ValueError: invalid literal for int() with base 10: ‘Total’
File “/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py”, line 180, in _async_refresh
self.data = await self._async_update_data()
File “/usr/src/homeassistant/homeassistant/components/ialarm/init.py”, line 83, in _async_update_data
await self.hass.async_add_executor_job(self._update_data)
File “/usr/local/lib/python3.8/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/ialarm/init.py”, line 74, in _update_data
status = self.ialarm.get_status()
File “/usr/local/lib/python3.8/site-packages/pyialarm/pyialarm.py”, line 125, in get_status
zone_status = self._send_request_list(’/Root/Host/GetByWay’, command)
File “/usr/local/lib/python3.8/site-packages/pyialarm/pyialarm.py”, line 67, in _send_request_list
total = self._clean_response_dict(response, ‘%s/Total’ % xpath)
File “/usr/local/lib/python3.8/site-packages/pyialarm/pyialarm.py”, line 232, in _clean_response_dict
response = response.get(i)
AttributeError: ‘NoneType’ object has no attribute ‘get’
Looks like your alarm is sending a string (word) when the integration expects a number.
You should open a new issue here, including as much detail as you can. Like what faulty behaviour you are noticing, the error log, and model of your alarm.
I asked github for help. However, I have found that the integration works if I do a server restart after each operation
Include that information as well.
Thank you for the help received. After updating home assistant the problem is solved. Greetings
