When I connect a zigbee device I can set a friendly name. It automatically get’s more cryptic entity IDs, though. Example:
sensor.lumi_lumi_sensor_magnet_aq2_battery
sensor.lumi_lumi_sensor_magnet_aq2_device_temperature
Would you recommend to rename the entity ID to a more friendly name, too, or to go with the autocreated ones? If so, is there a shortcut to rename all entities of a device at once? Also to prevent typing errors during batch renaming.
Thanks for sharing your experience.
