Any chance to integrate Digoo alarm systems?
I have a digoo Hama alarm system. It would be great if I can control it from HA, and use it as a group of sensors…
http://www.mydigoo.com/Digoo-DG-HAMA-All-Touch-Screen-Alexa-Version-433MHz-GSMandWIFI-DIY-Smart-Home-Security-Alarm-System-Kits-p-137.html
Any chance to integrate ?
Hello all,
I also have one Digoo Hosa alarm. It works very well but I wold like to integrate It in to hassio.
Does anyone has already did that?
Is there someone that could be interested in help me on this?
Thks
Hello, I’m interested in integrating Digoo hosa with any smart home software, so if you want we can try to find a solution…
Alex.
Hello, have you found any solution?
no solution yet
Yes its 433Mhz fixed code it works with RFlink or Openmqttgateway.
what do you mean? the hub of the alarm is connected to WiFI and can be controlled by mobile phone app “Easy Security” so I think the question is if this app can be integrated in Home Assistant somehow
I am also interested in an integration for the Digoo Hosa alarm system. I can write to the company but I do not know what exactly to ask for. Any suggestions on what they should do/change/add?
Anyone know if the Alexa integration, will allow conection, or act as a sort of bridge between the alarm system and Home Assistant?
What i’m thinking is that if you integrate google home/assistant to Home assistant, you are able to control and use most of the devices that are integrated in google home, like lights, speakers etc…
Maybe a similar connection could be made from Alexa…
Também comprei o Digoo DG Hama por conta da INTEGRAÇÃO com Alexa e até hoje não a tenho, ninguem consegue me dizer como integrar, não consigo ler o controle pelo Broadlink e nõa consigo ativar o Skill pois ele simplesmente nõa funciona!!!
