Thanks jason.
I’ll do same thing as per your advise. it works great. thank you very much.
Thanks jason.
Set up you phone as a Wifi access point.
Thank you.
Good idea! thank you very much for this brilliant ideas…
Waiting for the Sonoff SPM Main and 4 Channel Relay add-on units to be integrated into ESPHome and Home Assistant…
Or what are you using?
Which ones are the clip on ones you use ? @Jason_Rhodes
The ones I have are now discontinued along with the breakers but here is the current model for the multi9 series.
This one is with metering
