Other than pin, fingerprint and smartphone, is there any smart door lock that can be used with a fitness tracker such as Mi Band 2?
Apple Watch can. Or you could just use a BLE scanner and unlock when in range.
thanks for your idea.
I never use any smart lock before. I plan to start with Zwave lock such as this Yale lock.
Before I purchase this, may I know is it possible to unlock the door via HA automation?
I plan to set it as per your suggestion; place a BLE scanner near the lock. When it is in range, it will trigger an automation in HA to unlock the door.
