Any Experience with these Tuya/Benexmart/Zemismart US Switches?
I have been eyeing these switches because I have a dual dimmer module controlling a single bathroom fixture with two channels, and a bathroom fan switch next to it.
The dual module has a single phase in and it splits between:
  • the tiled backlight and
  • the vanity main lights (plus shower recessed lighting).
I would like to use the triple gang module to have one button be Zigbee associated to the backlight, one button be zigbee associated to the vanity lights, and the final button be an automation trigger for ‘all off’.
I know the dual dimmer has two ‘clusters’ with each cluster corresponding to a dimmer output . I am curious if anybody has owned these (switches) and knows whether they (the switches) support a per-button smart mode. Running new wires would not be very possible considering they go up, through the wall top framing, across engineered I-Joists, back down, then through a stud and are stapled for the entire run.
Thanks!
