I was wondering if this is compatible:
Or any good AliExpress?
Thanks guys!
Thanks guys!
There are compatibility lists on the z2m site and on ZigBee.blakadder.com
Thanks, the first search I did it there. But there is no lock compatible sell in AliExpress. That’s why I need some user recommendation.
MQTT introduces quite a security risk for locks if you want control via MQTT.
There are ways to mitigate this but obviously passing an unlock code via MQTT payloads in plain text or in any repeatable encoding is a problem.
MQTT’s login password is also one level of protection.
I see at least 2 available from ali.
Any possibility to share which ones?
I have nothing to show that the tuya lock you pointed to will not work, and z2m is pretty easy to get new devices into, but you might not want to bother with that.
I mean zigbee should be zigbee, but manuafacturers have weird interpretation of standards
