Specifically the AirDoctor i-series which have a wifi module. Planning to only use a single one for a very small room as its dimensions work out great.
You might want to check if it’s Tuya based or if the Tuya App will work with it. If so, then yes.
good point, thanks
I have an AirDoctor and was not able to pair with Tuya. It doesn’t seem its tuya-based. Did you have any success? I’d also like to find a way to integrate so I can be less reliant on their app.
