Any luck with full integration of Tuya based robotic vacuum?
Hi everybody!
Just wondering if any one of you had any luck and succeeded to fully integrate a Tuya based robovac?
I have AIRROBO T10+
I’ve managed to integrate it with Tuya integration, but it’s just a basic stuff like start/stop/dock/ping. The same goes for LocalTuya.
I tried to install this map extractor:
[tuya_cloud_map_extractor/README.md at main · oven-lab/tuya_cloud_map_extractor · GitHub
Although I managed to pull the map, I can’t seem to find a way how to do something with it, I just see it in HA.
That was never the goal, though. The main thing I’d be interested in is to be able to pull room commands. There must be a specific command send when I select e.g. kitchen and tap start, and a different command when I select kitchen with the dining area in SmartLife app, right?
Have any one of you integrated it?
Any help, even the smallest pointer, would be much appreciated. :pray:
I´m having the same issue with my own tuya based vacuum cleaner Concept vacuum cleaner
I tried official tuya integration, but I´m not able to turn the vacuum even on. I can see the total cleaned area, time, I can send robot to docking station, but it´s all.
With tuya local I have better resaults. I can also turn on the robot, I can see percentage of battery, and also can change intensity of cleaning. But it´s still not enought. There has to be way, how to control everything as from cloud app.
Any ideas? I can send some screenshots, but I don ´t thing, it will help.
Hopping on the train to see if anything comes of this. Would also be quite interested as I’ve recently purchased this one from Kogan
How did you manage to get the basic functionality you mentioned? stop/start/dock etc
That’s all I’m looking for, but when I attempt to add the air robo app account as a Tuya hub, I get an error about using the wrong app?
