Any news about the development status of the new controller?
Currently I am using an Aeotec 500 controller which I am running for a while. After the last Black Friday and some renovation I added a whole bunch of new (Shelly Wave) devices to it. All are fairly well spread around the house but somehow them and previously existing devices became totally unreliable. One day they are working the other day they won’t. I suspect the controller to be the cause as the devices are brand new and with the new ones the mesh topology should be even better than before. I also did trigger the new route function after the new devices were added.
So before looking to get my hands on a new controller I was wondering what the status of the controller is, which was mentioned in the “Zwave is not dead” blog article a while back? I would rather spend my money on that to support the project than spending it for some other vendor.
Unfortunately there has not been any update on the status anywhere or even a rough estimate when the controller might become available for purchase. Especially since what was written in the article sounded so promising I wanted to wait and not go for a Zooz 800 stick or something.
So I’d like to figure out if it’s worth the wait or what is going on? Maybe anyone in here knows anything? Thanks!
Would like to know that too, even though I have switched from an Aeotec Gen 5 to the Zooz 800. It would be nice to have an extra stick from HA itself, like the SkyConnect that I use.
You might want to check the logs for those Shelly devices. I just returned a bunch of them because their firmware is buggy. Among other things, it was flooding my z-wave network with a gratuitous number of pings. That kind of packet flood could cause reliability issues.
Thanks for the hint. I will check. I have a bunch of them but only a few do not work reliable. All with the same firmware. And some more fibaros which I choose to avoid in the future because of them not willing to make their firmware accessible outside their hub.
EDIT: logs did not look suspicious nor somehow flooded atm.
How is your experience with this one? I would prefer a HA stick as well as I do too have the SkyConnect one. However before I was aware of HA developing something I was between Homeseer and Zooz.
I am really happy with the Zooz stick. I used an Aeotec Gen 5 before. I could not backup it up, so had to repair everything manually. Have 63 devices connected now and it’s rock solid. No issues at all.
Thanks. Was there any reason you could not do a backup? I have the same Gen5 Stick currently in use and a lot of my devices sit behind switches in walls so having to take them out to repair will be a lot of work I would definitely like to avoid (also some are in outdoor blinds which I would then have to take apart to get to them as there was no other way to attach them).
I could not do a NVM backup with the stick, because of old firmware. The stick would also not update to a newer firmware as the model was too old. Needed a version build in or after a certain year. Aeotec mentions it in the documentation.
I eventually added the Zooz stick with an extra z-wave network. I did that using zwavejsui next to the zwavejs supervisor addon. Had them both connection to a different port.
Then I slowly removed one device from the old network and added it to the new one. Including all the in wall items. I mainly use Fibaro switches, so I was able to (un)pair them using the toggle switches. Did not have to open the walls. Took me a couple of days to have moved everything. Could have done it faster, but wanted to take my time and be sure everything was running ok. :slight_smile:
Before any device can be sold in the us it has to get FCC certified. One guy used the fcc listings to get a heads up on the nabu casa voice module. https://www.reddit.com/r/homeassistant/comments/1g931za/nabu_casa_home_assistant_voice_preview_edition/. You might be able to do the same for the new z-wave controller.
Also Aeotec is coming out with a new controller as well. Its a Z-Wave and Zigbee combo stick. https://ces-lasvegas.german-pavilion.com/en/sites/products-services/170460
Thanks for the FCC hint. I hope at one point (soonTM) we can fine some information on a roadmap. I don’t know how much longer I will wait for a new stick as every day another device fails with the old one which I still suspect to have issues…
Since Aeotec now released the new Z-Stick 10 Pro, I still wonder about the status of the development of Nabu Casas own zwave stick. Currently the one from Aeotec seems to be available only for the US market. I thought those 800 chips can serve all frequencies and it is just a matter of configuration. :thinking:
It continues to be under development and testing, so unfortunately the answer is still “soon”.
700 and 800-series can both be configured for any frequency, and in fact the specs for this controller claim “Z-Wave Long Range: US & EU (ready)”. At one point I was told the Aeotec Z-Stick 7 antenna was tune for each region, but I don’t know if that is really true, and if that would apply with the 10 as well.
Maybe the official online store you linked to now only services the US region and they’ll sell to other regions via resellers? You could send them an email about it, they are pretty responsive. FWIW the certification statement shows support for all regions, although it’s missing EU_LR (probably why spec says EU (ready), since that is gated by SDK version >= 7.23 and I believe certification is not allowed yet). https://products.z-wavealliance.org/products/5157?selectedFrequencyId=-1. I’d guess a future firmware upgrade should support EU_LR.
I have just received the new Aeotec Z Stick 10 Pro. I was hoping to upgrade my old Aeotec Gen 5+ stick. I have had nothing but trouble getting it to work.
Configuration of Z_wave JS UI gives me this message:
Driver: Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200) at Driver.sendMessage (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:6782:23) at ZWaveController2.queryCapabilities (/opt/node_modules/zwave-js/src/lib/controller/Controller.ts:1130:37) at Driver.initializeControllerAndNodes (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:1830:46) at Immediate. (/opt/node_modules/zwave-js/src/lib/driver/Driver.ts:1582:16) (ZW0100)
And log shows:
2025-03-31T20:27:55.167Z DRIVER Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
:6782:23)
.ts:1582:16)
I suspect I need to update the silicon labs driver. I have the following instructions but not sure how to execute this in Home Automation. Not sure how to find my kernel version for these instructions:
  1. make ( your cp210x driver )
  2. cp cp210x.ko to /lib/modules//kernel/drivers/usb/serial
  3. insmod /lib/modules/<kernel-version/kernel/drivers/usb/serial/usbserial.ko
  4. insmod cp210x.ko
Any help appreciated.
My problem was I used the default port it suggested during configuration. It should be:
ws://a0d7b954-zwavejs2mqtt:3000
Another confusing configuration issue is selecting the correct USB port. I have Home Assistant running in a proxmox VM and I passed through the USB stick. Even thought I only see one stick to pass through to the VM, when you go to configure the controller in Home Assistant you see two identical USB entries. One is for Z-wave, the other for Zigbee. You must enter the correct of these two when you configure Z-wave or the Zigbee controller as a device. Since you select one of two identical values in the dropdown it is confusing. In my case the first was Zigbee, the second Z-wave. Also know you must enter these USB values in both the Device configuration and the Z-wave JS UI configuration separately.
This is a good procedure:
