Is there anyone out there who has successfully added the 2843-222 Open/Close sensor and gotten a binary sensor for status??
Mine work. I have 3 of them. Not sure if I can answer any questions as I am not fluid with all this however I could try.
thanks haven’t been so far. trying work aroubds
do we know if it is just a bad sensor? Does it work in the insteon app? Maybe you need to click on the insteon app on the left and click on the sensor and load from device?
here is some info on mine and maybe that will help you compare?
Thanks for the ides. Since it’s batter powered and am away from home for a while we will see what happens when I get there. Right now it sis reading closed as it should.
