Any recommendation for an awning vibration sensor?
I use this: https://www.aqara.com/us/vibration_sensor.html
with a xiaomi hub and it works well.
Getting the sensitivity right is a bit tricky though.
/peter
Could you tell me more, how to get the sensitivity right
i think i set it to highest sensitivity and then i combine it with wind forecast - high wind comming = send alarm/retract awning.
Meaning that if i get vibrations and there is no or low wind ill ignore the warning. A high wind forecast will retract the awning regardless of the vib sensor.
