I’m looking for something to serve as an endpoint for: https://github.com/KoljaWindeler/ytube_music_player
Thanks!
Thanks!
Are you running anything on the pi?
Not right now, but I’m also looking to put ledfx on it. Home assistant is running on a different box.
Picoreplayer then.
I tried picoreplayer but it was not happy with the ytube/youtube audio streams. It plays a split second of garbled sound and then stops. The text to speech worked fine though.
Any ideas? (or a different suggestion?)
This issue comments suggests mpd and Kodi both work.
Mpd should be fairly lightweight. Kodi is feature rich but you’ll likely want a monitor/TV attached to configure it.
