did you have any trouble flashing & running Tasmota ?
Didn’t tried Tasmota yet. I choose espurna because you said this earlier: “Espurna is getting a tiny advantage”
Does Tasmota support the color temperature of the white?
espurna doesn’t as you can see here: https://github.com/xoseperez/espurna/issues/695
@Skaronator
for me the rgb strip reacts to the “white-temperature-slider”, with espurna.
I must admit i didn’t read the whole github issue which you linked. I will experiment.
If you have the opportunity, would you mind flashing Tasmota to your new H801?
There seems to be an issue cropping up with recent devices, where they will not be flashed to Tasmota, but will accept Espurna… we need more data. https://github.com/arendst/Sonoff-Tasmota/issues/2155
I’ll give it a try in the next few days.
The RGBW mode doesn’t work that well in espurna. If you set it exactly to white it’ll turn off the RGB LEDs but if it isn’t perfectly white it’ll instantly turn off the white. (Maybe this kind of issue would be fixed if I use it via HA over MQTT.)
I was assuming HA+MQTT…sorry.
Ah okay. The color settings in the Espurna web interface aren’t working perfectly.
I’ve updated the github issue. I was able to flash sonoff.bin
Edit: How did you configure the wifi password? The wiki says I should hardcore it while compiling or press the button multiple times and use a android app but the H801 doesn’t have a button.
Edit2: Got it working, looks like it is searching for WPS by default.
In reply to your contribution on the tasmota github issues :
This is the relevant part from my configuration.yaml
- platform: mqtt
state_topic: "stat/h80102/RESULT"
state_value_template: "{{ value_json.POWER }}"
command_topic: "cmnd/h80102/POWER"
payload_on: "ON"
payload_off: "OFF"
availability_topic: tele/h80102/LWT
payload_available: "Online"
payload_not_available: "Offline"
rgb_command_topic: "cmnd/h80102/COLOR"
rgb_state_topic: "cmnd/h80102/STATUS11"
rgb_value_template: "{{ value_json.StatusSTS.Color.split(',')[:3] | join(',') }}"
brightness_command_topic: "cmnd/h80102/DIMMER"
brightness_state_topic: "stat/h80102/DIMMER"
brightness_value_template: "{{ value_json.Dimmer }}"
brightness_scale: 100
on_command_type: "brightness"
qos: 0
optimistic: false
retain: false
Also i have this in automations.yaml :
- action:
- alias: read MQTT Power states on start-up
payload: ''
topic: cmnd/h80102/POWER
service: mqtt.publish
condition: []
- event: start
platform: homeassistant
Still getting {“Command”:“Unknown”}
Here my MQTT Settings in Sonoff:
And here the light cfg:
light:
- platform: mqtt
state_topic: "stat/H801-201/RESULT"
command_topic: "cmnd/H801-201/POWER"
payload_on: "ON"
payload_off: "OFF"
availability_topic: tele/H801-201/LWT
rgb_command_topic: "cmnd/H801-201/COLOR"
rgb_state_topic: "cmnd/H801-201/STATUS11"
brightness_command_topic: "cmnd/H801-201/DIMMER"
brightness_state_topic: "stat/H801-201/DIMMER"
qos: 0
optimistic: false
retain: false
Can you show the output from tasmota web console ?
For example :
14:33:28 CMD: somerandomcommand
14:33:28 MQT: stat/h80102/RESULT = {"Command":"Unknown"}
Not exactly sure what you mean. Here is the whole log after a reboot:
So the namespace (or whatever it is called in MQTT) seems fine, eg.: cmnd/H801-201/<command>
00:00:00 Project sonoff Sonoff (Topic H801-201, Fallback H801-201, GroupTopic sonoffs) Version 5.12.0
00:00:00 WIF: Connecting to AP1 FritzBox in mode 11N as H801-201...
00:00:03 WIF: Connected
00:00:03 DNS: Initialized
00:00:03 HTP: Web server active on H801-201.local with IP address 192.168.178.201
00:00:05 MQT: Attempting connection...
00:00:06 MQT: Connected
00:00:06 MQT: tele/H801-201/LWT = Online (retained)
00:00:06 MQT: cmnd/H801-201/POWER =
00:00:06 MQT: tele/H801-201/INFO1 = {"Module":"H801","Version":"5.12.0","FallbackTopic":"H801-201","GroupTopic":"sonoffs"}
00:00:06 MQT: tele/H801-201/INFO2 = {"WebServerMode":"Admin","Hostname":"H801-201","IPAddress":"192.168.178.201"}
00:00:06 MQT: tele/H801-201/INFO3 = {"RestartReason":"Software/System restart"}
00:00:14 MQT: tele/H801-201/STATE = {"Time":"1970-01-01T00:00:14","Uptime":"0T00:00:13","Vcc":3.137,"Wifi":{"AP":1,"SSId":"FritzBox","RSSI":100,"APMac":"CC:CE:1E:B4:77:F6"}}
00:01:23 CMD: somerandomcommand
00:01:23 MQT: stat/H801-201/RESULT = {"Command":"Unknown"}
00:01:37 CMD: cmnd/H801-201/POWER
00:01:37 MQT: stat/H801-201/RESULT = {"Command":"Unknown"}
00:01:41 CMD: cmnd/H801-201/POWER%20ON
00:01:41 MQT: stat/H801-201/RESULT = {"Command":"Unknown"}
00:01:52 CMD: cmnd/H801-201/POWER%20TOGGLE
00:01:52 MQT: stat/H801-201/RESULT = {"Command":"Unknown"}
00:02:00 MQT: tele/H801-201/UPTIME = {"Time":"1970-01-01T00:02:00","Uptime":"0T00:01:55"}
can you post the output of status 0
The Time isn’t correct. Currently checking why… it does make many DNS request to the timeserver but doesn’t set it, anyway but it shouldn’t matter with this issue.
00:01:18 CMD: status 0
00:01:18 MQT: stat/H801-201/STATUS = {"Status":{"Module":20,"FriendlyName":"H801-201","Topic":"H801-201","ButtonTopic":"0","Power":0,"PowerOnState":3,"LedState":0,"SaveData":1,"SaveState":1,"ButtonRetain":0,"PowerRetain":0}}
00:01:18 MQT: stat/H801-201/STATUS1 = {"StatusPRM":{"Baudrate":115200,"GroupTopic":"H801s","OtaUrl":"http://domus1:80/api/arduino/sonoff.ino.bin","Uptime":"0T00:01:15","Sleep":0,"BootCount":106,"SaveCount":204,"SaveAddress":"F8000"}}
00:01:18 MQT: stat/H801-201/STATUS2 = {"StatusFWR":{"Version":"5.12.0","BuildDateTime":"2018-02-09T14:54:51","Boot":31,"Core":"2_3_0","SDK":"1.5.3(aec24ac9)"}}
00:01:18 MQT: stat/H801-201/STATUS3 = {"StatusLOG":{"SerialLog":2,"WebLog":2,"SysLog":0,"LogHost":"domus1","LogPort":514,"SSId1":"FritzBox","SSId2":"indebuurt2","TelePeriod":300,"SetOption":"00000009"}}
00:01:19 MQT: stat/H801-201/STATUS4 = {"StatusMEM":{"ProgramSize":485,"Free":516,"Heap":22,"ProgramFlashSize":1024,"FlashSize":1024,"FlashMode":3}}
00:01:19 MQT: stat/H801-201/STATUS5 = {"StatusNET":{"Hostname":"H801-201","IPAddress":"192.168.178.201","Gateway":"192.168.178.1","Subnetmask":"255.255.255.0","DNSServer":"192.168.178.4","Mac":"60:01:94:6F:91:E7","Webserver":2,"WifiConfig":3}}
00:01:19 MQT: stat/H801-201/STATUS6 = {"StatusMQT":{"MqttHost":"192.168.178.5","MqttPort":1883,"MqttClientMask":"H801-201","MqttClient":"H801-201","MqttUser":"homeassistant","MAX_PACKET_SIZE":1000,"KEEPALIVE":15}}
00:01:19 MQT: stat/H801-201/STATUS7 = {"StatusTIM":{"UTC":"Thu Jan 01 00:01:19 1970","Local":"Thu Jan 01 00:01:19 1970","StartDST":"Thu Jan 01 00:00:00 1970","EndDST":"Thu Jan 01 00:00:00 1970","Timezone":4}}
00:01:19 MQT: stat/H801-201/STATUS10 = {"StatusSNS":{"Time":"1970-01-01T00:01:19"}}
00:01:19 MQT: stat/H801-201/STATUS11 = {"StatusSTS":{"Time":"1970-01-01T00:01:19","Uptime":"0T00:01:15","Vcc":3.138,"Wifi":{"AP":1,"SSId":"FritzBox","RSSI":100,"APMac":"CC:CE:1E:B4:77:F6"}}}
can you activate debug output ? Main Menu / Configuration / Configure Logging / Web log level = 4 More debug
Then send an mqtt command, and post the console output ?
By the way, how are you sending the mqtt commands ? Home Assistant + Mosquitto, or some other MQTT app ( mqtt.fx, mqttlens, … ) ?
Trying to turn on via Home Assistant:
00:00:47 RSL: Received Topic cmnd/H801-201/DIMMER, Data Size 3, Data 100
00:00:47 RSL: Group 0, Index 1, Command DIMMER, Data 100
00:00:47 MQT: stat/H801-201/RESULT = {"Command":"Unknown"}
So MQTT is working fine it is the command that is not working. If it’s MQTT fault then it would work when I typ the command in the console, right?
Could you say say a command that would turn on the light via console? Tried POWER ON
, TOGGLE
, COLOR
, COLOR 1,1,1
, COLOR #333
, COLOR 333
all with cmnd/H801-201
Prefix and without.
From the console you would type power on
, or power off
, or dimmer
No prefixes or anything.
example :
17:05:41 CMD: power on
17:05:41 MQT: stat/h80102/RESULT = {"POWER":"ON"}
17:05:41 MQT: stat/h80102/POWER = ON (retained)
17:05:44 CMD: power off
17:05:44 MQT: stat/h80102/RESULT = {"POWER":"OFF"}
17:05:44 MQT: stat/h80102/POWER = OFF (retained)
17:05:50 CMD: dimmer
17:05:50 MQT: stat/h80102/RESULT = {"Dimmer":100}
I’im guessing the mqtt command is wrong, here is what i get when turning the device on :
17:09:44 RSL: Received Topic cmnd/h80102/DIMMER, Data Size 3, Data 100
17:09:44 RSL: Group 0, Index 1, Command DIMMER, Data 100
17:09:44 MQT: stat/h80102/RESULT = {"POWER":"ON","Dimmer":100,"Color":"255,255,255,0,0","CT":499}
17:09:45 CFG: Saved to flash at F5, Count 5517, Bytes 1648
what is the output of setoption15
Umm I had only tried it with %20 in the console which um wasn’t that clever since this is for URL encoding.
I set debugging to maximum for everything now it’s not responding anymore. Gonna reflash give me a second
if you don’t have the serial console connected, there’s no use in sending all the debug info to serial
if you aren’t hosting a syslog server, there’s no use in sending all the debug info to a syslog server
