Any RTL_433 experience with La Crosse Technology Rain Gauge 724-1409
Anyone have this rain gauge and know if it works with the RTL_433 tool? I was using thejeffreystone’s excellent add on to read a neighbor’s Accurite weather station rain gauge, but they moved. So, now I need to buy one ;-( This device uses 433Mhz and there are other La Crosse devices listed in the protocols list, but not this one. I’m hoping someone has tried it.
https://github.com/thejeffreystone/hassio_addons
Thanks!
Joe
Joe, did you have any luck getting the rain gauge to work with HA?
I did not end up using the La Crosse. I ended up using an Acurite station and have been very happy with it (AcuRite Iris 5 in 1). I was able to add in other non-acurite devices (Ecowitt soil moisture hygrometers WH51) at the same time using Jerrery Stone’s add-in. There are some La Crosse devices listed in the supported protocols so as long as the frequency of the Ecowitt matches your SDR and you can find the device on this list, I suspect it will work. hassio_addons/acurite2mqtt/PROTOCOLS.md at 41c80ed11bf7afc7c222989d54661de3578110a0 · thejeffreystone/hassio_addons · GitHub
