Anybody has experience of a compatible smart plug sold on Amazon India. Here are some plugs being sold:
Homemate - Apparently it uses SmartLife app.
Wipro 16 A
Acasa
Wipro 16 A
Acasa
i have purchased wipro,
it works fine.
but dont know to to add it to HomeAssistant.
Please guide if u have already added
thanks
@kirpat @trumee join us on HA India discord
https://discord.gg/ZRMUXnjw2Q
Bumping an old thread I suppose. However to answer your question, you can use the Wipro smart plug with Home Assistant provided you disconnect it from the wipro next app and instead set it up in Smart Life. You can then use the official Tuya integration OR Local Tuya to avoid the cloud and yet have full control to the plug and its sensors.
I purchased https://amzn.eu/d/48sfP8G today and the sensors don’t seem to be available on hass. Any thoughts?
You using the official Tuya integration for this? Try switching to Local Tuya if possible. I use ~45 Tuya devices (plugs, lights, switches) by various manufacturers and they work great.
Thanks for the reply
Yes, I’m using Tuya. Will try localtuya, I had tried once already but somewhere got too stuck and didn’t have the patience last time. Any resources that you can share?
@johnjacobkenny I am new to home assistant. Could you please explain the steps for adding the Wipro Smart Plug into Home Assistant.
Follow this Blog and use LibreTiny.
Can you share the link again.
Philips Wiz 16 amp plug works right out of box after setting up with wiz app.
I am looking for 10amp plugs which don’t use tuya at all.
Please do suggest if you know any.
I haven’t tried this but there are mentions about Zunpulse 10A plugs that works. I haven’t seen that in stock for so many months. I am also searching for 10A plugs. Alternative option is, use normal 6A socket with smart switch that you can control with home assistant.
Yo link expired can i get new link …?
did it show power usage ?
Get the wipro 16A model that you can flash via libretiny. It’s not straight forward but you can make it to work. Buy it directly from their etail portal and not from the jungle. You will save 150₹ per plug.
That model supports power monitoring.
Bought 2x Wipro 16A smart plugs after reading the thread. Managed to flash ESPHome using tuya-cloudcutter method based on the blogpost link shared earlier.
Now 1 of the smart plug doesn’t get detected on the network, neither shows up online. Both the plugs can’t turn on eletronics and are basically dud. Wondering what I did wrong.
From your smartphone WIFi are you able to see standalone hotspots when the wipro is plugged to power? Check your GPIO pins are correct.
Nah. Nothing. I dumped the cheap powerplugs. Not wasting time after wasting my money.
I used the Tapo P110 16A socket along with HACS in Home Assistant.
