Will the linked unit work with my Mr Cool DIY unit? 36k BTU condenser with 12k BTU air handler
Ordered one
shipped already to you, Ruud
Hi Guys,
I have a Midea AC and also use the Midea Aircon plugin.
Everything is working fine, exept the climate thermostat card/entity will not update till I execute a command via the card! This means, if I use the wired airco controller the status in hass is not updated!
Any ideas how to fix this?
regards,
Jurgen
I have a Midea AC, seems like it has V3 protocol and there are no realtime updates through the cloud, so seems like I have to make a local server, but I can’t find any info about it. can you give a link to these instructions?
I’ve got the osk103 dongle, popping it open i wonder if it’s possible to make use of any of the pins on the dongle pcb. or maybe flash it with the fake server? seems like this thing can be reprogrammed no? i’m sure some of you more knowledgeable folks have probably already given it a look, but incase no one has here’s a pic of the pcb.
If not i’ll try the esphome route,
I own a Midea AC model MAP12S1BWT, it has wifi integrated into it (no dongle). Does anyone know which library, if any, supports this one?
(Edit: After playing around with it more I decided to just jump in head first and got it working with the Midea Smart Aircon repository. Thanks guys!)
can you send the repository url
Mean this one? GitHub - mac-zhou/midea-msmart: This is a library to allow communicating to a Midea AC via the Local area network.
But the ESPHome Dongle is much more stable
Yep, that’s the one I used. I don’t have a dongle on mine unfortunately, and being in the middle of a massive heat wave I’m not really willing to risk disassembling my AC to find it at the moment
For now, this seems to work, even if the device shows unavailable half the time (it did when using the Midea app too, I assume it’s wifi module is just crappy)
No feedback on this one?
Not really…
Can you see the led on the esp01 flashing?
Should flash about once every seconds (indicating serial communication)
Oh…wait…this is not about the esp01 dongle, but the midea custom addon…
Not sure if that still works…especially with latest version updates it is problematic.
I have used it for 1 week and was then fed up with it, and I’m happy I got the esp01…
I can you recommend one… if you’re not comfortable making one yourself, you can order a prebuilt one as mentioned in this thread.
Succes ermee
just ordered 4
Hello! I have devloped the PRO version of Midea dongle
- pre-flashed and ready to use, just plug&play;
- connection to home WiFi via web interface, no flashing required;
- autodiscovery in HomeAssistant;
- hundreads of users of my sticks around the word;
- PRO means that it allows users to connect additional sensors (like PIR, sound, light, relay, and ay other types of sensors een without soldering) - have a look on photos by the link.
- factory soldering.
Available at:
- official store (faster and cheaper order processing, WORLDWIDE delivery) - smartlight.me
- eBay - eBay link;
Hi.
Does anyone know if it is possible to use the component (that i would use on d1 mini ) with the Midea Right air conditioner? On the specifications reports the wifi ce-sk103 (and not ce-Osk103)
Thanks very much
The new version already supports 8370.Need to get token and k1.
adb logcat | grep doKeyAgree
Thank you for hard work! Appreciated!
Don’t worry about the model, just run the following command on a machine on the LAN to know if it is supported.
pip3 install msmart
midea-discover
After latest msmart update with my so far perfect OSK-102 I receive (integration unavailable) and:
Logger: msmart.security
Source: /home/pi/homeassistant/lib/python3.8/site-packages/msmart/security.py:44
First occurred: 11. august 2021 23:38:24 (1 occurrences)
Last logged: 11. august 2021 23:38:24
aes_decrypt error: ValueError('Data must be aligned to block boundary in ECB mode') - data: b8ef3ce0bb99ff143f7b56cef08efaf00ae4a118329a84d433196fad29362c4d18553c158dda08b20f6f593b287191b855b9a77a26e0b09b122a114a21d370b25a5a011168004 etc.
Can I roll back msmart somehow or what is going on?
Best, JR
