Any tips for tuning audio for voice assistant on ESPHome?
I have assist up and working well with my phone as well as a respberrypi 2 with homeassistant-satellite. Whisper and openWakeWord are hosted on another machine. Whisper is running the base model.
I’ve just set up an esp32 with the INMP441 microphone and wake word works pretty well but whisper doing a poor job interpreting the audio from it.
Does anyone have any tips for tweaking the noise_suppression_level, auto_gain or volume_multiplier to get whisper to do a better job? How do you know which one to tweak and how far up or down?
esphome:
  friendly_name: Office VA
esp32:
  board: esp32dev
  framework:
    type: esp-idf
    version: recommended
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "redacted"
ota:
  password: "redacted"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Office-Va Fallback Hotspot"
captive_portal:
i2s_audio:
  i2s_lrclk_pin: GPIO27
  i2s_bclk_pin: GPIO26
microphone:
  - platform: i2s_audio
    adc_type: external
    i2s_din_pin: GPIO13
    pdm: false
speaker:
    dac_type: external
    i2s_dout_pin: GPIO25
    mode: mono
voice_assistant:
  microphone: mic
  speaker: big_speaker
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.0
  vad_threshold: 3
  on_listening:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Slow Pulse"
  on_stt_vad_end:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Fast Pulse"
  on_tts_start:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        brightness: 100%
        effect: none
  on_end:
    - delay: 100ms
    - wait_until:
        not:
          speaker.is_playing:
    - script.execute: reset_led
  on_error:
    - light.turn_on:
        red: 100%
        green: 0%
        blue: 0%
        brightness: 100%
        effect: none
    - delay: 1s
  on_client_connected:
    - if:
        condition:
          switch.is_on: use_wake_word
        then:
          - voice_assistant.start_continuous:
  on_client_disconnected:
    - if:
        condition:
        then:
          - voice_assistant.stop:
          - light.turn_off: led
light:
  - platform: esp32_rmt_led_strip
    disabled_by_default: true
    entity_category: config
    pin: GPIO4
    default_transition_length: 0s
    chipset: SK6812
    num_leds: 1
    rgb_order: grb
    rmt_channel: 0
    effects:
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
          min_brightness: 50%
          max_brightness: 100%
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 50%
script:
  - id: reset_led
    then:
      - if:
          condition:
            - switch.is_on: use_wake_word
            - switch.is_on: use_listen_light
          then:
            - light.turn_on:
                red: 100%
                green: 89%
                blue: 71%
                brightness: 40%
                effect: none
          else:
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    on_turn_on:
      - lambda: id(va).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
      - lambda: id(va).set_use_wake_word(false);
    name: Use Listen Light
    optimistic: true
    on_turn_on:
    on_turn_off:
external_components:
  - source: github://pr#5230
    components:
      - esp_adf
    refresh: 0s
esp_adf:
What settings did you end up with here? I just setup a new device and am finding the results pretty bad. Takes a lot when for the wake word to be detected
I ended up using these settings for my Esp32 devices. I no longer have the Pi2 set up.
I’ll give those values (for volume and noise suppression etc.) a shot and see how they go. Thanks.
EDIT: I get a compile error due to pin assignment as soon as I add the esp-adf external component stuff which without prevents me using the VAD setting for the voice assistant…
