im still trying out code and so every now and then I stuff my config and I end up waiting till the samba mounts so I can quick view the log find the line and fix. but when this happens and I save the yaml I cant reboot the system using “reboot” via ssh.
all that does is shut down the ssh and not let me login again until I physically turn off and on.
reboot the specific container .
for example if you made a change to the configuration.yaml of the home-assistant.
you only need to restart home-assistant container.
docker restart homeassistant
// homeassistant is the name of the container
use this to see all the running containers : docker ps
and this for containers that has exit : docker ps -a
note: if you make a mistake on the configuration.yaml the home-assistant container has exit.
you can also use the docker log homeassistant
to see the live or last message of the container .
note: if you see an error about docker running follow the Manage Docker as a non-root user from here https://docs.docker.com/engine/installation/linux/linux-postinstall/#manage-docker-as-a-non-root-user
more about docker command here: https://docs.docker.com/engine/reference/commandline/docker/#child-commands
I just realised after reading https://home-assistant.io/hassio/architecture/
that I can reboot from within the app itself.
Yes everting can done with UI
and if UI not responding due error in configuration, how can i reboot ?
with hassio CLI inside ssh addon
I’ll be the first to admit that I suck at RTFM, some form of adult ADD…
I had no idea there were hassio commands to be used under SSH. Thanks!
