I’m using a 2413S PLM with the Insteon integration and would like to be notified when I press up (on) on a Switchlinc switch even when the switch is already “on.” Ditto for pressing down when the state is already “off.” ISY has this capability, so I know Insteon’s hardware supports it.
I understand sensors in HA get around this issue via a force_update
property, allowing HA to trigger events even if the state does not change. However, I do not know if I, as a random user, can set this property or if it has to be supported by the Insteon integration.
Any ideas?
