Any way to add comments when editing a dashboard card
Hello all!
Is there anyway to do the subject? If so, is there a keyboard shortcut to comment the line when editing the card manually. Below is the area of the software I am talking about:
No.
The yaml from the UI editor is stored as json, and json does not support comments.
You can only use comments in yaml mode.
Ahh, I follow you. Thank you for your response @tom_l
If this can help, Some cards allow a “description” field, which you can leverage to take notes.
It survives the yaml/json conversions.
I actually looked for an “alias” option in the Entities card before posting so I could suggest that. No luck. Just checked again. No description option either unfortunately.
Seems like the OP card header shows “vertical-stack” as the card type.
Could definitely be wrong but I think the description field works with it.
There is no such a “description” option.
Funny but you can add any option and even save the card.
But the UI editor will not work.
This is an unofficial way to comment cards:
__comment: Comment here
Card comments
It saves and the card still works, but the visual editor doesn’t
I would not use it. It could all come crashing down with the next frontend update.
This is my way:
if need to describe smth in UI itself - I use markdown:
type: vertical-stack
cards:
  - type: markdown
    content: |
     some comments
     even an image may be added here
    style: |
      ha-card { color: red; }
  - type: ...
    ... any card
Thank you for this @Ildar_Gabdullin and thank you for all of the help and suggestions you have given me any multiple other threads. Very thankful for your help!
