Any way to make multiline YAML substitutions?
Lately I’ve been keeping my ESPHome configs separated into a generic device file (in this example, a certain model of smart plug) and a file with substitutions specific to the item I’ll be installing it on. This works great for things like the name, but I’m stuck on trying to use this for something like the linear_calibration values where there are multiple lines in the substitution.
I have been trying to use the | symbol as the YAML standard specifies, which almost works but I get various errors. For example, this is the closest I’ve gotten to a working config:
(in the generic yaml)
    power:
      filters:
      - delta: 0.01
      - calibrate_linear:
        - ${power_calibration}
(in the item-specfic yaml)
power_calibration: |
    0.0 -> 0.0
  - 1.0 -> 1.2
This generates errors when trying to compile:
while parsing a block mapping
  in "/config/esphome/coffee_maker_plug.yaml", line 2, column 3:
      id_name: coffee_maker_plug
expected <block end>, but found '-'
  in "/config/esphome/coffee_maker_plug.yaml", line 7, column 3:
      - 1.0 -> 2.0
To answer my own question, I was able to get it to compile like this… But it’s an ugly hack and I feel like there has to be a better way to do it…
      - calibrate_linear:
        - 0.0 -> 0.0
        - ${current_calibration_1}
        - ${current_calibration_2}
        - ${current_calibration_3}
        - ${current_calibration_4}
        - ${current_calibration_5}
  current_calibration_1: 1.0 -> 2.0
  current_calibration_2: 0.0 -> 0.0
  current_calibration_3: 0.0 -> 0.0
  current_calibration_4: 0.0 -> 0.0
  current_calibration_5: 0.0 -> 0.0
It makes for a maximum of 5 calibration points and I just replace 0.0 -> 0.0 with any measured values.
I wish yaml had support for lambdas, something like:
somestuff_tmpl: &somestuff
  - thing: {param1}
  - thing: {param2}
    thingie_with_param2: some_literal
something1: *somestuff_tmpl{
  param1: too
  param2: bar
but then again, this would make it turing complete, and it’d be only a matter of time when someone would propose standard libraries and built-ins
perhaps jsonnet could output yaml for you, but you’d lose some of the tooling that exists for yaml, and perhaps ESPhome could be improved (debatable) by allowing for more than one config language…
