Any way to manage a bunch of Raspberry PIs in HA?
I’ve ended up with about a dozen Raspberry Pi’s of various flavors in my home setup and will likely add a bunch more. They are doing fairly special purpose tasks — like a Raspberry Pi Zero reading the status of a UPS via NUT, and I’m hoping to set up a few smart displays, etc…
The problem is, each of these Pi’s is a full-fledged computer that needs at least a little management — like software updates, occasional restarts, etc. I don’t want to have to memorize a bunch of passwords and remind myself to SSH into each little random box every month or two to check on it. I’d much rather have a way to basically adopt the Pi’s themselves as devices in Home Assistant and create a dashboard to expose things like storage space, uptime, current IP address, etc. and, ideally, be able to issue commands like shutdown, restart, and run software updates.
Is there an integration out there that lets me do this or something like it? Any tips would be appreciated!
Thanks!
Check this one: SSH Integration - Connect your servers to Home Assistant
Thanks! At quick glance that looks like exactly what I was hoping for! I’ll look into it in more detail!
Use mqtt and create script that has them send stats
