I’m running HAOS in a ProxMox VM. I have two network adapters, to enable access to devices on an IOT vlan. Everything work great except when occasionally after a reboot, the “secondary” network adapter gets defined as the Default.
Here is the correct setup. The problems occur when the enp0s19 adapter becomes the Default after a reboot.
Is there any way to force/define the enp0s18 adapter to always be the Default?
Thanks!
