If you go to developer tools, under the states tab, you can put in the entities you’re tracking (persons or tracking devices) and set the state to whatever you want to test. (This does not set the actual device. It just sets how HA sees it.)
Using this, I was able to test a number of zone-related interactions without leaving my desk chair.
From the above comments I don’t think it’s clear how to test the triggering of an automation like this:
alias: Send notification when leaving home
description: ''
- platform: zone
entity_id: person.christian
zone: zone.home
event: leave
- service: notify.mobile_app_christians_phone
message: Christian left home
mode: single
Setting the state to “away” for person.christian doesn’t work for me. What would work?
It will be one of the device trackers attached to the person that you want to manipulate, you can’t just change the state of the person entity. You need to use the service device_tracker.see to manually change the GPS coordinates of the device tracker to make Home Assistant register a change of location.
