Creating your own theme is overkill IMO.
Yeah, I definitely wouldn’t do that but I think there is a way to change the one code (maybe css?) for the icon color. Still not really the route I would like to go.
Not correct for lights.
Assume we have lights in Entities:
type: entities
entities:
- light.hall_ceiling
- light.koridor_ceiling
- entity: light.kitchen_ceiling
card_mod:
style:
hui-generic-entity-row $:
state-badge $: |
ha-state-icon {
{% if is_state(config.entity,'off') %}
color: red !important;
{% endif %}
Repeat, this is an example for Entities.
As for minimalistic card particularly - this is up to Weston to find out…
Use Code Inspector to determine a path to your element.
P.s. Do not suggest to use this notation:
color:
{% if .... %}
black
{% else %}
red
{% endif %};
Use this:
{% if .... %}
color: black;
{% else %}
color: red;
{% endif %}
did you test:
style: |
:host {
--paper-item-icon-color:
{% set state = states(config.entity) %}
{% if state == 'off' %} black
{% else %} var(--primary-text-color)
{% endif %};
and adapt to your liking?
short version:
style: |
:host {
{{'black' if state == 'off' else 'var(--primary-text-color)'}};
Is there a chance this is not supported by the minimalistic card?
My bad habbit of lazy computer scientist, the less I’m writing, the best ![]()
Open Minim.card.
If you see ON lights of different colors → lights following their state (on/of) and their temperature/color/… - like in other HA places.
I see. I’m sorry, this is the first time I’ve ever done this.
…the harder people (incl. you after some time) will understand the code))
Try-fail-repeat-succeed)
100% agree
Below is what I have.
type: vertical-stack
cards:
- states:
- arm_home
- arm_away
- arm_night
type: alarm-panel
entity: alarm_control_panel.alarmo
- type: grid
square: true
columns: 3
cards:
- type: custom:minimalistic-area-card
title: Back Patio
area: back_patio
shadow: true
hide_unavailable: true
state_color: true
darken: true
tap_action:
action: navigate
navigation_path: /dashboard-automatic/back-patio
entities:
- entity: light.all_back_patio_lights
- entity: switch.back_patio_fountain
- entity: switch.back_patio_speaker_power
title: Back Porch
area: back_porch
shadow: true
state_color: true
darken_image: true
tap_action:
action: navigate
navigation_path: /dashboard-automatic/back-porch
entities:
- entity: light.all_back_porch_lights
- entity: switch.back_porch_fountain
- entity: switch.back_porch_speaker_power
The light icons do seem to follow their actual colors in the physical world.
Means - you may use same method. But you need to find out a path to this element.
Use Code inspector, right mouse click on any bulb - an see what element is selected on the right panel. You need to define a property on a MINIMAL “depth level” - i.e. right there it is needed.
What is this? Trying to google it. I assume some sort of css or html reviewer? Is there a product you recommend?
Code Inspector - it is a name of this feature in Chrome.
In other browsers called differently.
In Chrome is opened by F12.
Oh, ok. I installed a cssviewer google chrome extension. I will use what you speak of.
This is the line that is highlighted when I right click on the icon we are speaking of:
<action-handler-minimalistic-area-card style="position: absolute; width: 50px; height: 50px; transform: translate(-50%, -50%); pointer-events: none; z-index: 999; left: 573px; top: 580px; display: none;"><mwc-ripple></mwc-ripple></action-handler-minimalistic-area-card>
EDIT:
But it looks like any icon I right click on, on the card highlights that same information.
Now point a mouse on a bulb and make right click.
Select Show in code inspector.
Which element is selected in a tree on the right panel?
Keep trying and do not open these hidden “details”:
do not open
card_mod:
style:
.buttons ha-icon-button:not(.state-on):
state-badge $: |
ha-state-icon {
color: red or whatever !important;
