Hello all,
Could I get some help on figuring out if the below is doable and how to do it possibly.
Below is what I have so far but I’m noticing it sets the color to black and it doesn’t change after the icon is pressed. (card-mod). I would like it to be black as just the default color but then go to whatever color it used to go to without using the card-mod. For instance, I think bulbs go to the color they actually are if you have the “state to color” turned on in the entity settings.
Is there a way to do this? (So when its off or inactive, icon is black, and its yellow when on or active)
type: custom:minimalistic-area-card
title: Back Patio
area: back_patio
shadow: true
hide_unavailable: true
state_color: true
darken: true
card_mod:
style: |
:host {
--card-mod-icon-color: black;
tap_action:
action: navigate
navigation_path: /dashboard-automatic/back-patio
entities:
- entity: light.all_back_patio_lights
- entity: switch.back_patio_fountain
- entity: switch.back_patio_speaker_power
Olivier1974
(Olivier Toussaint)
December 11, 2023, 6:37pm
2
You can use conditions in card_mod and reuse existing theme colors
card_mod:
style: |
:host {
{% if is_state('binary_sensor.zigbee_ping', 'on') %}
rgba(0,255,0,0.15)
{% else %}
var(--primary-text-color)
{% endif %};
This is an example, not your final code.
In your situation, you should not use the --card-mod-icon-color tag.
Have a look at examples from the card-mod thread.
EDIT: I’m not using custom:minimalistic-area-card so I can’t help more
Olivier1974
(Olivier Toussaint)
December 11, 2023, 6:54pm
3
Olivier1974:
I’ve found this example in the card-mod thread
title: Office
area: office
tap_action:
action: navigate
navigation_path: /home-dashboard/office
entities:
- fan.office
- light.office
card_mod:
style: |
ha-state-icon$: | {
color: red;
That you might be able to combine with my previous reply.
Thank you for showing me this! I apologize as I’m not the greatest with customizing things just yet based on code.
This has to be done for each individual entity in my situation? (previous photo)
Why would I not want to use the method you have shown? I’m sorry for not following you on this. This is the first time I’ve ever gotten into the custom cards/ abilities etc.
Thank you for spending your time to help!!
Olivier1974
(Olivier Toussaint)
December 11, 2023, 6:56pm
6
Yes, you’ll have to find a way to do it for each individual icon, that is the reason why you should not use the --card-mod-icon-color, which is all or nothing.
Follow the link I gave and search for minimalistic-area-card in the topic, you’ll find other examples.
I have found all of these but haven’t been able to get one to work and I’m hoping there is a way to not have to do this on a one by one basis for entities but I have a feeling there may not be:
card_mod:
style: |
:host {
{% if states('light.all_back_patio_lights') != 'on' %}
--state-cover-active-color: var(--yellow-color);
color: yellow;
{% endif %}
card_mod:
style: |
:host {
styles:
icon:
- color: |
if (entity.state == 'on') return 'white';
else return 'yellow';
card_mod:
style: |-
${ if (ROOM_STATE === 'on') {
'ha-card {--card-mod-icon-color: yellow;}'
} else {
'ha-card {--card-mod-icon-color}'
Olivier1974:
card_mod:
style: |
:host {
rgba(0,255,0,0.15)
{% else %}
{% endif %};
Here all my posts which may be useful: NOTE: Do not forget to add a “card_mod:” keyword before “style:” (new in card-mod 3). And also read this important note to create optimized code. In most examples here a code is NOT optimized - just to describe a DOM navigation. Entity card post rotating icon (by @dolodobendan ) Entities card (including some special row elements - button , section , divider ) post font-size for Entities card post Entities card with attributes post Slider entity …
Not a problem. For some reason I couldn’t get those combinations to work either.
- type: grid
square: true
columns: 3
cards:
- type: custom:minimalistic-area-card
title: Back Patio
area: back_patio
shadow: true
state_color: true
darken: true
tap_action:
action: navigate
entities:
card_mod:
style: |
:host {
{% if is_state('light.all_back_patio_lights', 'off') %}
rgba(0,0,0,1)
{% else %}
{% endif %};
Olivier1974
(Olivier Toussaint)
December 11, 2023, 7:29pm
9
card_mod apply to the full card, not on the entity (so you have to pay attention to the indentation).
You’ll have to find, in the examples of the topic which one allow to colorize “per icon”
Olivier1974
(Olivier Toussaint)
December 11, 2023, 7:34pm
10
What about
title: Eingang
area: eingang
hide_unavailable: false
state_color: true
card_mod:
style: |
:host {
{% if is_state(config.entity, 'off') %}
black
{% else %}
{% endif %};
entities:
- light.all_back_patio_lights
- switch.back_patio_fountain
- switch.back_patio_speaker_power
So the below actually worked but like you said, when I clicked on the patio lights, it changed all icon entity colors and not just the patio.
- type: grid
square: true
columns: 3
cards:
card_mod:
style: |
:host {
rgba(0,0,0,1)
{% else %}
{% endif %};
title: Back Patio
area: back_patio
shadow: true
state_color: true
darken: true
tap_action:
action: navigate
entities:
Let me give it a try right quick.
Olivier1974
(Olivier Toussaint)
December 11, 2023, 7:37pm
13
I changed it a bit, a ) was missing, some indentation, …
I have hope with the config.entity
That one doesn’t seem to be working I don’t believe. Below is what I have:
card_mod:
style: |
:host {
black
{% else %}
{% endif %};
title: Back Patio
area: back_patio
shadow: true
state_color: true
darken: true
tap_action:
action: navigate
entities:
The below portion is working but changes the whole row of icons based on just clicking one of them:
card_mod:
style: |
:host {
rgba(0,0,0,1)
{% else %}
{% endif %};
Olivier1974
(Olivier Toussaint)
December 11, 2023, 7:44pm
15
I’m not giving up but as I’m not using that specific card, I can’t test my solutions myself.
So, I think you might need someone else to help you. At least I taught you that you can re-use theme colors and conditions …
EDIT: as the author of the card redirect to the entities option for the card, you can still have a look at the card-mod for entities.
Yeah for sure. I’ve posted over in the thread you linked me to and got my hand smacked for tagging someone that I’m sure knows whether it can be done or not.
We’ll eventually get there, I just doubt it will be on my own
Thank you very much though!! I’m like you, I think it’s doable, I just don’t know how at the moment.
Olivier1974
(Olivier Toussaint)
December 11, 2023, 7:47pm
17
Tagging someone is against the rules of the community.
I found that out the hard way.
#created not happy individuals
Olivier1974
(Olivier Toussaint)
December 11, 2023, 7:52pm
19
My last attempt, using card_mod at entity level
entities:
card_mod:
style:
hui-generic-entity-row:
state-badge {
color: :
black
{% else %}
{% endif %};
Pay attention to indentation
Let’s see what happens.
Below is what I used:
Looks like a “no go” again on my end.
title: Back Patio
area: back_patio
shadow: true
state_color: true
darken: true
tap_action:
action: navigate
entities:
card_mod:
style:
state-badge {
color: :
black
{% else %}
{% endif %};
I found the below at this link:
Thanks, lldar.
I tried what you suggested (below), but that didn’t change the garage door from purple to red (as hoped).
type: entities
entities:
- entity: cover.main_garage
type: simple-entity
card_mod:
style: |
:host {
{% if states('cover.main_garage') != 'closed' %}
--state-cover-garage_door-open-color: "#ff0000"
{% endif %}
state_color: true
[Screenshot 2023-09-16 at 10.15.36 AM]
So worst case I could go that direction. Kind of weird but maybe it would work. (It looks like they are changing the whole themes color in the core settings)
you can change all state colors in your themes , no need for card_mod, and 100% reliable and supported by core, always preferable to any custom solution, did you have a look at that?
just create a default-adjusted theme, (not as you did I the card_mod) and only change the state-colors in that to your desire, and leave the rest. easy as can be
default_adjusted:
state-binary_sensor-garage-on-color: var(--alert-color)
would be all it takes for the garage_door binary
